Motor mount flange
Old Dec 8, 2020 | 05:20 PM
thatsrealnice's Avatar
thatsrealnice
Motor mount flange
Noticed that the flange on frame that motor mount mounts to, has a crack in it. Is this okay to have welded, or should I look for a replacement, or leave as is. Thanks.
Old Dec 8, 2020 | 09:05 PM
mark a.'s Avatar
mark a.
Sure, weld it up.
Old Dec 8, 2020 | 11:49 PM
1TonBasecamp's Avatar
1TonBasecamp
Yep, weld it up like normal and that's perfectly fine. Not uncommon to see cracks there for some reason. Yours looks kind of beat up too. I wonder if that's just it's natural look (the factory was not always a perfectionist back then) or if maybe the mounting nut came loose and the engine was beating it up for awhile.
Easy fix still though, if you know basic welding.
If not, but you want to try it yourself anyway, I would grind it a bit, clean it a lot, and weld it up good and solid, Others will know details like what rod or wire to use, and all that.
Maybe even do your best to grind it flatter than it is when you're done, so that the new mount will sit flatter with a more supported base than it looks like there was originally.
Or am I not seeing it correctly? If you pug a new mount up against it you should be able to tell how much area needs to be flat.
Good luck.
Paul
Old Dec 9, 2020 | 12:24 AM
thatsrealnice
Perch
Good luck.
Paul
Yeah. The motor mount was barely hand tight, so I think the engine was moving the mount back and forth and rubbed the perch. I don't have any welding supplies. I'll take if off tomorrow and take it by a welding shop down the street and see what they can do.
Old Jun 12, 2024 | 01:20 PM
Old Guy F-250's Avatar
Old Guy F-250
I am with Tbear, 70 14 is a great all purpose rod.
Remember the 70 means 70,000 # psi tensil strength....
Pretty strong !!!!!
dobenator
Aug 9, 2020 05:13 PM
resonateur
Nov 14, 2016 03:42 PM
Holehawgg
17
Jul 8, 2012 07:41 AM
Ole' gray
Feb 18, 2012 07:30 PM
RustyTrustyF150
Oct 20, 2005 04:59 PM
