1998 Ranger 4x4 lights blinking
Old Nov 20, 2020 | 02:58 PM
TomSlick1's Avatar
TomSlick1
I have a 98 Ranger and the 4x4 lights are flashing 6 times every couple of minutes. When it does this while driving, the transmission goes into a neutral state until I let off the accelerator. When I do, it slams back into gear. Anyone have any experience with that?
Old Nov 21, 2020 | 12:46 PM
pawpaw's Avatar
pawpaw
Welcome to FTE.
I see you don't have any replies yet, so will see if I can get things started. Good idea to have posted up the 4X4 flashed code 6. Still Lots of unknowns, so use, borrow, or come by the inexpensive ELM scan tool & running diagnostic freeware FORScan on the viewing device of your choice as discussed here https://www.ford-trucks.com/forums/1...-scantool.html. As this powerful diagnostic combo is tweaked for Fords, it can query All of the vehicle computer / controllers for trouble code clues. Then post up All code Numbers in case you have more than one problem, as together they can help focus a trouble shoot.
Did this problem come about suddenly after some event???
Is the 4X4 system functional, such that it'll shift into & out of 4X4 Hi & Low & into 4X2 ok & the indicator lamps all indicate correctly & you can hear the 4X4 transfer case shift motor work when the 4X4 buttons are pushed ??? Some beginning thoughts for consideration, let us know what you find.
noggins
Nov 10, 2017 07:20 AM
SwampFox112
Feb 19, 2015 07:52 AM
BigB4000
Jul 22, 2005 09:53 AM
smoky1978
Jan 15, 2005 09:07 PM
mrmusic
Jan 17, 2004 06:33 PM
