Modular V10 (6.8l)
2001 vs 2006
Old Nov 16, 2020 | 09:17 PM
Kyle Eleuterius's Avatar
Kyle Eleuterius
2001 vs 2006
I have a 2001 v10 and it is knocking and i found a 2006 v10 and was wondering if there is a problem dropping in and what if anything that will need to be done?
Old Nov 17, 2020 | 06:40 AM
Dweber85rc's Avatar
Dweber85rc
Pretty sure it won't work. The 2001 is a 2v the 2006 is a 3v and they are not interchangeable depending on what the 2006 came out of. Ford used 2v in the rvs and big vans for quite a while after the 3v switch in the f250+
Old Nov 17, 2020 | 11:23 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Depends on where the 2006 came from - if it's an E-series, it's a 2-valve, but you'll have to swap the oil pan, oil pump pickup, and possibly the oil filter/cooler adapter.
Everything else should bolt up - again, ONLY if it's a 2-valve.
A 3-valve will not work without major rewiring, dash replacement, PCM, even the ABS system.
F350ShortBedDually
Modular V10 (6.8l)
Sep 13, 2020 06:17 AM
bdsellers
Aug 7, 2020 08:05 AM
sldhed
Jul 22, 2011 07:17 PM
dpl454
Oct 20, 2008 06:43 AM
