TORQUE SPECS FOR FUEL LINES? 11 6.7
Looking for fuel line nut torques for all lines pump to rails rails to injector. Anything helps, the only answer I have so far is, "we just tighten them real good at out shop"
THANK YOU
I think the old girl still has some fight left in her. Started as an unplugged vgt solenoid, so i pulled the turbo and freed the unison ring, figured i mightys well do injector seals since its been leaking, broken hold down bolt on either side, now im doing head gaskets, 3 weeks into waiting for parts :P
THANK YOU
The following users liked this post:
By broken bolt, i mean totally seized. I tried finding someone with a promax tool to bore out the seized broken bolt with them still on the truck, all my local machine shops are either too busy, or don't want to mess with it so i ordered new heads and figured it happened for a reason, truck has 286k miles on it figured it was probably time anyhow. I drilled it out and retapped it as straight as I could I just wasn't happy with it and don't want to worry about it when i'm out of town.
I don't have the answer your looking for but just wanted to comment on how I respect guys like you keeping a high mileage truck going.
Is she stock or deleted?
Got her all put back together. Was nerve racking for the first few cranking attempts then she finally fired off.
Never had the vgt turbo working on this truck before, what a difference that makes on hills with a loaded trailer.
Also put the Amsoil BMK28 dual bypass on just to be sure I get anything out that might have gotten into the engine while it sat open.
Thank y'all for your help.
AlexBrokeMyTruck
1999 to 2016 Super Duty
11-03-2020 09:33 PM
MONAVIERONJON
08-25-2012 06:47 AM
Snowseeker
10-06-2011 03:01 PM
peterF450
21
03-23-2008 07:42 PM
