Ebp sensor
Old Oct 31, 2020 | 09:55 PM
Homerunking2394's Avatar
Homerunking2394
Ebp sensor
the tube the feeds the sensor on the front of the engine broke. How vital is this that I fix it? Any way to bypass the sensor to make the truck run better?
Old Oct 31, 2020 | 10:10 PM
udsuth78's Avatar
udsuth78
Fixing it and having a clean working sensor has been know to improve mpg. I saw a 1.5 mpg bump personally.
Homerunking2394
how much is involved to install a new line
Old Oct 31, 2020 | 10:28 PM
jstihl's Avatar
jstihl
Its not hard at all if you don't have 2 alternators. Just make sure you pre soak fittings on both ends with pb blaster or my favorite is hilco lube if you can get your hands on it
Old Oct 31, 2020 | 10:48 PM
Homerunking2394
seems easy then!
Old Nov 1, 2020 | 06:53 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
There is a new design out that will not look like your original line, unless it has already been swapped. @DieselOrings and @Riffraff Performance are great sources of OEM and quality parts and they are both sponsors here on the FTE.
https://www.dieselorings.com/1999-2003-ford-7-3l.html
https://www.riffraffdiesel.com/99-03-super-duty-7-3l/
Old Nov 1, 2020 | 07:44 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
This is a very old video of mine that shows the cleaning procedure. You can use it to help guide you in replacing it. It's very easy.
The EBPS is important for fuel mapping, but don't get it confused with the EBP Valve which are unrelated.
Old Nov 1, 2020 | 12:21 PM
Ford Firefighter's Avatar
Ford Firefighter
I’ve heard you can cap the nipple on the manifold, clean your sensor, cut off the tube right below the sensor and crimp it closed. So that you don’t have to worry about the sensor getting dirty again.
Does this all sound right?
Old Nov 1, 2020 | 12:22 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Yes but I highly recommend against this. But yes, you could do that.
Old Nov 1, 2020 | 12:24 PM
Ford Firefighter
Per my curiosity, why is the negative side effects of doing that?
Old Nov 1, 2020 | 02:22 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
The EBPS is used by the PCM to control fuel injection. Not having it installed correctly would result in a default setting for the fuel table.
You can try this for yourself. Start your truck, then while it is running unplug the sensor. You will hear a change in the way it runs. This is safe to do, I have done it. That said, I'm not responsible for any explosions haha
Old Nov 1, 2020 | 02:52 PM
Ford Firefighter
Haha understand! Okay so again I’m just trying to understand this! But would unplugging the sensor and caping the pipe have the same result? Because I have had it come unplugged unknowingly and you definitely know something happened!
I just have been told that if you cap it, the PCM will presume you never have “too much” back pressure and give it the “max” fuel?
Old Nov 1, 2020 | 03:26 PM
Homerunking2394
My sensor is plugged in but the tube is now rotted off at the halfway point between fittings..it broke after I had to remove the plate the sensor is on. Weird design
Old Nov 1, 2020 | 03:39 PM
Ford Firefighter
Well I suppose I’d order a new tube (Do NOT get the Dorman) it will not fit correctly, unless they changed things recently!
I cleaned my sensor a while back with carb cleaner and a few q-tips, made the truck run a Lot better! My tube was sealed off with soot!
fordtruck661
15
Feb 19, 2014 02:37 PM
mikerans
18
Mar 20, 2013 01:00 PM
natew
Jan 16, 2010 09:47 AM
afonda
Feb 17, 2009 01:21 PM
wgw
Oct 15, 2006 08:16 PM
