Front and rear spring code decoding help
Old Oct 31, 2020 | 05:14 PM
My4Fordtrucks's Avatar
My4Fordtrucks
I read through dozens of pages of spring threads. From what I saw Ford no longer published the spring rates but would someone be able to tell me what C 7 means? Possibly an old chart/ table would be the same spring? I saw a thread with the rear code 7 but it only listed the part number and no other information.
Old Oct 31, 2020 | 06:13 PM
JJF20's Avatar
JJF20
Did you try these sites?
https://www.autoandtrucksprings.com/...tr=spring+code
https://www.sdtrucksprings.com/ford-...-code-listings
Edit: I ended up calling ATS directly, they helped me sort all my questions out, they were really knowledgeable.
Old Oct 31, 2020 | 07:40 PM
My4Fordtrucks
I did but was hoping to confirm what I saw. I can’t get the ATS site to pull up any spring code info. The SD site shows 1,655# as the replacement. Sent ATS an email. I bought rear springs from them for the Bronco II.
I discovered the springs were broken all the way through on both sides after I bought the truck. I put 1,700# springs on it from JBG but they lifted the rear a couple inches over stock. That didn’t matter since I also raised the front for the plow. I’m thinking about removing the plow and going back to stock.
Old Oct 31, 2020 | 08:10 PM
JJF20's Avatar
JJF20
Frustrating.
Jesse73iditurbo
Apr 1, 2021 10:32 AM
wrxin
May 30, 2014 09:09 PM
Bowie
Nov 8, 2011 10:49 PM
420CREW
Feb 20, 2010 06:29 AM
rjwood5
Sep 19, 2006 01:22 AM
