Non-greasable Spring Shackles
Old Oct 17, 2020 | 10:02 PM
Tenderpaw's Avatar
Tenderpaw
I have a 52 F1 and would like to get rid of the metal greasable shackles and use rubber bushings instead. I'd still like to keep the stock shackle frame mounts if possible along with the stock springs. Does anyone know of a kit to do this?
Thanks,
Dave
Old Oct 17, 2020 | 10:15 PM
ALBUQ F-1's Avatar
ALBUQ F-1
No, no kits I'm aware of. If you look at the shackles and spring eyes, there just isn't room to add a layer of rubber that would do any good.
Old Oct 18, 2020 | 09:07 AM
Mixer man's Avatar
Mixer man
What you're asking for cannot be done without a redesign.
Old Oct 18, 2020 | 09:33 AM
Tenderpaw's Avatar
Tenderpaw
Other than the TCI Parabolic rear spring kit, does anyone know of a kit with new frame brackets that will accomplish my goal? Thanks.
Old Oct 18, 2020 | 01:47 PM
bigwin56f100's Avatar
bigwin56f100
Can I ask why you’d want to do this?
Old Oct 18, 2020 | 02:39 PM
Mixer man's Avatar
Mixer man
Maybe has a strong aversion to grease guns, but which I think is part of the retro charm. I have about 350 zerks on all my equipment combined, that's why I have an electric grease gun that I bulk load.
Old Oct 18, 2020 | 02:47 PM
bigwin56f100
the only reason they went to the rubber suspension is because of lack of maintenance. If you grease the fittings regularly they will last forever ( which you and I already know)
Old Oct 18, 2020 | 06:10 PM
Tenderpaw's Avatar
Tenderpaw
Less maintenance. I honestly hate greasing cars. I don't like repacking wheel bearings either. Also, it seems like it would be smoother to have rubber bushings.
Old Oct 18, 2020 | 06:54 PM
mytoolman's Avatar
mytoolman
EASIER TO LUBE use these items:
These three "lube the existing zerks EASIER" items work for me:
1.
Amazon Amazon
2.
Amazon Amazon
3.
Amazon Amazon
I originally had a few seriously jammed up zerks and the components they attach to....carefully applied heat with a propane torch, and THEN using the Innovative Products of America Rejuvenator filled with gasoline solved the jammed with old grease problem...(Inovative DOES NOT MENTION USING GASOLINE they PROBABLY DONT WANT YOU TO DO THAT EITHER) but I was having no success until I did that.on those extra stubborn remaining few that the tool didnt work on with just the "Light Oil" suggested in the instructions...now I can grease everything...
Old Oct 19, 2020 | 12:40 PM
Mixer man's Avatar
Mixer man
Also, a system used on lots of large machinery, lets you grease many points from just one zerk. I adapted this to my bulldozer and it saves a lot of legwork.
Many multi-point lube systems are on the market -
http://www.lincolnindustrial.com/Cat...s/Quicklub.pdf
And for those that think grease is "ewww", there is always Jiffy Lube or Grease Monkey.
Old Nov 10, 2020 | 09:07 AM
hooler1's Avatar
hooler1
1. https://www.amazon.com/LockNLube-fit...N9G69T7FPH6RPB
2. https://www.amazon.com/Innovative-Pr...38592789&psc=1
3. https://www.amazon.com/Milwaukee-264...e%2C223&sr=1-5
Gasoline used in a zerk rejuvenation tool? That's interesting. I might very carefully give it a try. I have tried lots of different things. It seems though that Liquid Wrench penetrating oil worked the best for me so far, even better than Kroil. But I still have two that are stuck one on a front spring and one on the rear and looking like they will need to be replaced.
Old Nov 10, 2020 | 09:48 AM
Scotty's 52 F3's Avatar
Scotty's 52 F3
I haven't looked at my bushings since I replaced them so this is a guess. How about Delrin/Acetal bushings? I machine my own Delrin bushings on my lathe for my rock crawler. Got tired of replacing the rubber and even poly bushings that didn't last. I made some for my Ram 2500 control arms and my buddies Jeeps. They don't need lube. The trade off when replacing stock rubber bushings is noise transfer. Probably not much of a difference going from a brass or steel bushing. Just a thought
Old Nov 11, 2020 | 06:46 AM
avf100's Avatar
avf100
My truck is a 55 & I got these from Mid-Fifty.
Maybe you can make these work on your truck.
The 55 springs are 2" wide.
sand_fiend
Mar 12, 2013 02:27 PM
Major Marvin
Feb 4, 2013 05:57 AM
moejr
Dec 28, 2012 01:53 AM
brian0357
Offroad & 4x4
Apr 14, 2006 07:13 PM
Thoth88
Jul 20, 2004 10:19 PM
