Removing Spring Leafs
Old Sep 27, 2020 | 10:58 AM
Steves55's Avatar
Steves55
I would like to remove a few leafs from the front and rear of my 55 F-100 to lower and would like to know if this can be done without removing the entire leaf spring pack? If so, what is the safe way to do this and tools needed? Thanks. Steve
Old Sep 27, 2020 | 11:38 AM
bigwin56f100's Avatar
bigwin56f100
Yes it can be done on the truck. You’ll need basic hand tools to remove the u bolts and you will need a die to chase the center bolt because when you remove leaves the threaded part of the center bolt will not have enough threads
Old Sep 27, 2020 | 12:51 PM
Steves55's Avatar
Steves55
Thank you very much. Will I need any clamps to keep the springs from flying once the U-Bolts are removed or is that only needed when the entire leaf pack is removed from the vehicle? Sorry of this is a dumb question just want to avoid serious injury or death.
Old Sep 27, 2020 | 01:02 PM
bigwin56f100
Have your jack stands on the frame so the springs are hanging. I do one side at a time. Use your floor jack to support the axle once the u bolts are off.
when you loosen the center bolt to can put a c clamp on it but they won’t go flying around no hidden force. Easy peasy
also I only remove 2 leaves it’s a lot of work for 3/4”
Old Sep 27, 2020 | 01:50 PM
Steves55's Avatar
Steves55
Thank you. Hopefully I will get a decent lowering from removing a couple leafs.
Old Sep 27, 2020 | 04:14 PM
1956_F100's Avatar
1956_F100
First, get new centering bolts, and maybe a couple extra as you might be doing this several times. Mid-fifty has them and I think I also saw them at Rock Auto. Clamp the spring pack with two c-clamps before removing the centering bolt. Then slowly loosen the c-clamps. Depending on how long the new centering bolts are, you might need the c-clamps to bundle the leaves back together.
Old Sep 28, 2020 | 08:15 AM
Steves55's Avatar
Steves55
Here's a photo of my truck. The more I look at it I am not sure if it will be worth the effort to lower it.
Old Sep 28, 2020 | 09:13 AM
abe's Avatar
abe
I like the stance the way it is
Old Sep 28, 2020 | 09:53 AM
AllenV's Avatar
AllenV
I like the stance and the color. What color is that?
Old Sep 28, 2020 | 11:52 AM
Steves55's Avatar
Steves55
Thanks Abe and Allen. I beleive the color is aqua blue but sice it was already painted when I bought it, I along with the previous owner are unsure. I have seen this color on other 55s however. Steve
GM4WALLS
Jan 9, 2016 05:36 PM
56FOneHundred
Oct 24, 2011 07:22 PM
jrandjen4ever
Jun 12, 2010 05:53 PM
joe hoffman
Mar 8, 2006 07:23 AM
skater2570271
Dec 1, 2003 01:39 AM
