Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Need help decoding vin
Old Sep 10, 2020 | 10:35 PM
Gothicfreak92's Avatar
Gothicfreak92
I have a 63 mercury 3 ton. I've been trying to find a vin decoder to decode my vin but have been having no luck. This is the plate on the truck. Can anyone help?
Old Sep 10, 2020 | 11:08 PM
85e150's Avatar
85e150
Welcome to FTE!
vinwiz.com VIN Decoder
Made in Ontario in Jan '66 as a '66
F700, 25000 GVWR
Engine code D is the FT 330 2v HD version, with the larger crank snout, distributor and oil pump drive as well as the other FT features.
The decoder says 352 but it's wrong. 352s were never installed in mediums.
That's all I can do as I do not possess a decoder ring.
Lots of fellow F700 owners in the Large Truck forum.
Does the VIN on that tag match the title? The VIN is also stamped on the top of the frame near the RF wheel. If the numbers don't match, then someone may have replaced the door and left the tag from the donor in place.
'63 or '66 you've landed in the wrong forum. Check those numbers and let me know if you want to get moved to Large Truck.
Old Sep 11, 2020 | 06:36 AM
abe's Avatar
abe
Wrong forum or not, let's see pics of this beast!
(Mod note, threads merged)
Old Sep 13, 2020 | 02:07 PM
Gothicfreak92
Need help deciding vin
Was wondering if I can get help deciding the vin on my truck.
Also if possible, need part number for passenger side drum brake wheel cylinder.
Old Sep 13, 2020 | 02:09 PM
Gothicfreak92
Sorry, front passenger side steer
Old Sep 13, 2020 | 05:27 PM
85e150's Avatar
85e150
Threads merged. The further decode won't necessarily help you with brake parts. Do you have that brake apart? If so, what is the inside diameter of the drum and the width of the shoes? With that info, and the year and model, you should be able to find those parts through NAPA and other sources.
Also, see post 2. You thought this was a '63 Mercury? Does the VIN on that tag match the title?
Old Sep 13, 2020 | 08:27 PM
Gothicfreak92
Old Sep 13, 2020 | 09:30 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Question 1963 Mercury 3 ton
I'm not going to decode this, because all the info will be wrong if it's actually a 1963. If the truck turns out to be a 1966, then I will decode it.
1961/65 Canadian VIN's/Warranty Plates are completely different than 1966/68 Canadian VIN's/Warranty Plates that are the same as US trucks.
This VIN decodes to a 1966 F700 w/a 330 2V Heavy Duty FT engine assembled in Oakville Ontario Canada.
Doors are the same: 1961/66 F100/1100. Warranty Plate located on the left door face below the latch on 1963/66's.
The problem is: People replaced damaged left doors with used doors. 99.9% of the time, they failed to install the original Warranty Plates on the replaced doors.
IF this is a 1963 w/a 292 or 302/332 Y block V8, the distributor is behind the carburetor. FT engines have the distributor in front of the carburetor.
Truck is registered/titled by its specific VIN. IS this the VIN on the trucks registration/title?
EDIT: See post #13.
Old Sep 13, 2020 | 10:07 PM
Gothicfreak92
I havent registered the truck yet. As for the distributor it is in front of the carb. What does FT mean?
Old Sep 13, 2020 | 10:24 PM
Gothicfreak92
as for the year I could be very wrong. the gentlemen I got the truck from said in his add it was a 63. I've had no luck trying to find this body style for 63. Its been 64 and up.
from what I can tell you is it's a 5 spd with a 2 spd rear end. The splitter is electric. It's got power brakes, manual steering.
would you mind trying to do it as a 66?
Old Sep 13, 2020 | 11:01 PM
85e150's Avatar
85e150
The FE engine is a car and light truck engine introduced in '58. The FT is a truck version intro'd in '64, The distributor in front and the appearance as a '64 or newer would point to the door tag being correct. Do you have a title for it?
Old Sep 13, 2020 | 11:19 PM
NumberDummy
1961/66 F500 and larger series trucks look pretty much the same except for the specific year grilles, placement of the parking lamps and certain emblems.
1961/64 parking lamps are within the grille, 1965/66 parking lamps are located in the upper grille panel. 1961/62 use different hood side emblems than 1963/66.
1965/66 front hood ornament w/a V8 is different than 1961/64, 1965/66 with an I-6.
I'll decode the '66 info...
Old Sep 13, 2020 | 11:54 PM
NumberDummy
Also if possible, need part number for front passenger side wheel cylinder.
F70 = F700 (gas).
D = 330 2V Heavy Duty FT (Ford Truck) engine.
C = Oakville Ontario Canada Truck Assembly Plant.
805160 = 1966.
174" Wheelbase.
J = Rangoon Red.
F702 = F700 (gas), 23000 lbs. GVWR
M81: M = Medium Beige Crush Vinyl & Medium Beige Cody Pattern Woven Plastic // 81 = 81A Standard Cab.
N = Clark model 2622-V 5 Speed Manual Transmission.
G3L:
G3 = Eaton model 16802 Two Speed Rear Axle / 6.50/9.04 / 17,000 lbs. Rear Axle Capacity.
L = Ford-Rockwell/Timken 6,000 lbs. Capacity Front Axle with Heavy Duty Kelsey Hayes Front Brakes.
23,000 lbs. Gross Vehicle Weight Rating.
164 net HP @ 3,800 RPM
A64202:
A6 = FoMoCo of Canada Ltd. Western Ford Division, where the original selling dealer ordered the truck from.
4202 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot."
C4TZ-2061-B .. Right Front 1 1/16" diameter Wheel Cylinder with 15" x 3" Kelsey Hayes H/D front brakes and 6,000 lbs. front axle capacity / Obsolete
RPN PARTS in Erie PA has 1 = 888-864-9305.
MCDONALD OBSOLETE PARTS in Rockport IN has 1 = 812-359-4965.
PARTS HOUSE CLEARANCE in Oroville WA has 2 = 250-878-3498.
Also try NAPA
craig clifton
Sep 8, 2020 12:49 PM
Jayson Mark
Large Truck
Jul 14, 2020 05:07 PM
Drew Lear
Large Truck
Feb 27, 2020 10:39 PM
Damen69
Nov 19, 2016 10:28 AM
stikmanfishin
1961 - 1963 F100 Unibody
Nov 14, 2014 11:49 AM
