351/400m Emissions Testing
I have had some experience. In 1993 I bought a '79 CJ7 with an AMC 360 in it. I was stationed in New York and needed it to pass their stringent emissions standards. I had no idea how to do it, but had a good friend that did know, and we got it done. Knowing more now, I could probably easily get your engine to pass Tennessee standards, but my fix isn't cheap. First, the engine internals have to be good. If the rings are worn, valves are leaking, etc., it ain't gonna work. But assuming you have a good engine, put a new catalytic converter on it. Install a factory type muffler. Install a Air/Fuel Ratio gauge. Cut the belt on the smog pump. Install a Edelbrock Performer intake manifold. Install an Edelbrock AVS2 650 cfm carburetor, preferably a 1905 which has manual choke. Yeah, you'll see a lot of comments on carburetor choices, but this is the one I'm best at tuning. I prefer manual choke always, but for testing purposes it's just a little insurance to make sure an electric choke doesn't screw up and cause it to run rich during testing. Install new spark plugs. New rotor and cap. New plug wires. New air filter. New PCV valve and hose.
Now you need to be able to tune it, or have someone that knows how. This is a very simplified explanation. Using 91 or 93 octane non-ethanol fuel, set your total timing as high as you can get it without detonating Under a Load. It's probably gonna be 34-38 degrees advanced. Using the A/FR gauge and a vacuum gauge, tune your carburetor to the leanest you can get it without detonating. After you pass testing, it'd be a good idea to richen up the carburetor tune a bit, and retard the timing a couple degrees. Once you're satisfied with timing and carburetor tuning, pull the plugs and clean or replace them before you go for testing. Make sure your air filter is clean. Before pulling into the bay for inspection, do some moderately aggressive driving to heat up the catalytic converter.
If you have to get this thing tested every year, you should make a record of everything you did to tune it for testing & retune it for driving.
I don't know for sure that it's stock, but it's not far from it if the internals have been modified. I do have to pass this every year, so I'll definitely be keeping track of what I do.
Also, will I even have a smog pump on the F350?
Getting everything back on the beam with the factory specs in the shop manual is how this will work. Voltages, temperatures (thermostat for example) fuel pressure, idle mixture adjustments, jetting ... ignition timing etc etc. This stuff has to be measured and verified. Aftermarket parts look the same as factory approved parts, but there really are differences, and those differences are sometimes really difficult to find when troubleshooting.
The first thing you probably want to do is a cylinder compression test, by the book.
Warm up the engine some, remove all the spark plugs, prop open the throttle, use a fresh charged good battery and record the highest psi reading for each cylinder. If you read the shop manuals, Chiltons, MoToRs, etc, all of them start with the compression test.
The reason is because if the cylinder bores or piston rings are worn badly, or exhaust valves are burnt, then it is a waste of time and money to do a tune up. Find out what it is you have to work with. You're "probably" OK, but ... then again maybe not....
It will never pass smog if the engine needs an overhaul. See where I'm goin' with that?
You mentioned EGR earlier. I do remember that we had it hooked up during testing, then blocked it off with a homemade plate and a couple of gaskets after I got the decal. I wish we could have tested it both ways, to see how much difference it made. The friend that helped me has passed, and I don't remember every little thing we did after testing. I do remember removing the catalytic converter, ran dual exhaust, blocked EGR, added a four hole 1" spacer, and had to jet up the Edelbrock 650 quite a bit to get A/FR down to acceptable level. His shop was fairly well equipped for the time, and had an exhaust pipe probe for A/FR reading. The whole thing was such a pain, that I sent the title to my dad and he registered it in my home state, so I wouldn't have to worry about NY's tough testing every year.
Regardless can you post the test. We need to know where you are failing is it at idle or at high engine RPM''s these limits are not that hard to meet with an engine that is in any sort of reasonable condition.
If it is at idle, the idle air just needs adjusting. If it is at higher RPM the carb is over fueling on the main circuit. Regardless you are running rich and that explains the high HC (hydrocarbons) and CO Carbon Monixde.
So let us know where you failed.
PCV--if the valve is worn or stuck, you could be getting oil. Oil will drive the HC up, and probably CO. But because you don't have cats I'm not sure what CO standard they are working with. Focus on HC for now.
Clean oil--even if the PCV is working right, if you have fuel contaminated oil due to short trips or overfueling, you will get those fuel fumes sucked back into the engine which will raise HC.
Oil burner--If you are leaving a blue cloud due to rings, you stand little chance of cleaning up HC. Worn valve seals usually make the more visible smoke on start up and under deceleration, when vacuum is the highest. Usually the test doesn't run on deceleration afaik and from what I've seen when getting cars smogged here.
And yes, see post 11 about posting the initial results.
