nylon timing gear
Old Aug 24, 2020 | 09:59 AM
jem44357's Avatar
jem44357
nylon timing gear
Did all 300's come from the factory with the nylon timing gear?
Old Aug 24, 2020 | 05:40 PM
fordman75's Avatar
fordman75
No 300 came with a nylon timing gear. A lot of the Ford V8's had nylon covered teeth on the timing chain sprockets.
Some of the 300's came with a fiber/composite cam gear. All of the EFI 300's came with the fiber cam gears because of the knock sensors. If replacing timing gears I always go with a metal ones.
Old Aug 25, 2020 | 07:29 AM
jem44357's Avatar
jem44357
Thank you!
monoman
Jun 12, 2005 01:58 PM
jerrycarl
Jul 6, 2004 03:06 AM
SPROCKET
Nov 10, 2003 01:29 PM
