when I run the AC at lower speeds, the engine run hotter: on the temperature indicator, where it says "normal" the needle stays around the "m". with the AC running, it will go all the way over to hot.
Do I need a better fan (stock) ? or is this something I just have to deal with. The engine is a 460 that was just rebuilt ( with RV cam)
Thanks
Just getting my a/c hooked up recently, I ran into the same concern.
As asked, what is the tstat temp?
When it's idling in park on a/c max and the temp rises, can you confirm when/if the fan clutch kicks in? Not only by listening but also by feeling the air movement behind the fan.
Once it does the temp should come back down. Not all the way down to the point as if the a/c wasn't on but definitely lower than when it's not kicked in.
For reference - on my recently rebuilt 460 with a 180 tstat and 4 row aluminum radiator when in park idling with the hood open, a/c on max and fan clutch kicked in the temp gauge is between R-M and the thermostat housing reading roughly 180 degrees.
You will run hotter with A/C as the A/C condenser is shedding heat right in front of the rad. One thing you can do if your truck is not fitted is add a heater core shut off.
Otherwise, you may need a higher-capacity radiator.
Adding the shut off valve before I got the AC working did not raise the temp but I am also using a 4 port valve to keep hot water going to the intake manifold as I have EFI exh. manifolds.
When I got the AC working I did see the temp go up just a little because of the heat the condenser puts out right in front of the radiator but the gauge still reads pretty low.
I have a 300 six and run a shroud and a fixed 4 blade fan, no clutch.
Dave ----
The factory had specific cooling setups and higher output alternators when the A/C option was ordered. These trucks are getting pretty old and have gone through a lot of owners. Things may have gotten swapped over the years, I would check to make sure you have the proper radiator, the proper fan and the proper pulleys on the front of the engine. It should also have something to raise the idle speed when the A/C is activated.
I don't believe the 86 460 had the tps to bump the rpms up with the a/c. When testing the other day with mine I was getting about a 90 rpm drop when at idle.
This is a worthwhile modification. Being an 86 your simplest options are a manual valve or one that is engaged automatically in recirc mode.
While this will help your in-cab A/C vent output temps, just doing it with no other changes will increase the overall coolant temp.
NO adding a shut off valve will NOT increase coolant temps it will lower them. It seems lots of people really have no idea how the cooling system actually functions
Care to elaborate? Always happy to expand my understanding.
By adding a shutoff valve and turning it on so the flow is stopped you are removing a radiator from the system. I did not say the impact would be significant or even noticeable (assuming the heater is off).
I looked at the wiring diagrams for 1986. I think you are correct. They have some exceptions in the diagram notes and the 7.5 liter was one of them.
When the AC is on or the Heat is off you are not moving any air over the heater core, it is not shedding any measurable heat. Instead, you are just dumping near engine temp coolant back into the cooled coolant from the rad and raising it's temp before it even hits the engine.
Speaking from experience I would add that having good coolant at the proper mixture is important to the BBF. I had this issue twice and cured both times by by changing the coolant. 1970 LTD w/429ci and a 1976 Thunderbird w/460ci.
Thanks for the explanation. I can see the logic in that when the hvac is off at which time it's likely a wash as far as overall engine coolant temp.
But I wouldn't recommend installing a bypass to address or assist in the OP's situation nor would I say that it isn't shedding measurable heat. Aside from a leaking core, the only other reason I know of in these trucks for bypassing the heater core is to improve AC temps and Vent temps (when set to Cool since that determines whether air moves through the core). This wouldn't be done if the heater core wasn't having a noticeable impact on the in-cabin air temp even if the blend door is set to Cool.
So I'll retract my statement on it increasing engine temp and just say that I recommend the heater bypass but only for the purpose of improving the Cool air temp in the cab.
