Sponsored by: Real Truck
Gas cap light on and code
Old Aug 7, 2020 | 10:39 PM
woody367's Avatar
woody367
04 F250 5.4, so the gas cap light came on a few weeks ago. I checked the cap and it was tight. I cleared the light and then it came back on and the check engine light came on with code P0455. Looked it up and said EVAP leak. readr some threads about the code and checked a few things. Gas cap gasket looks good and the filler neck rim is clean. Was looking for a broken or loose hose but did not find anything. Should I just get a new gas cap before replacing the purge valve? Do not want to just throw money into new parts if it is not needed. Any suggestion ? All; lights are off right now but the engine started to run rough tonight. Thank you
Old Aug 8, 2020 | 09:10 AM
Djosbun's Avatar
Djosbun
It's never the gas cap. You probably have a failed purge solenoid, as it's a moving part and is a common failure on all makes and models of cars.
If you do not know how to replace this part, a mechanic will easily be able to resolve this for you at not too steep of a price.
-- Dave
Old Aug 8, 2020 | 09:34 AM
projectSHO89's Avatar
projectSHO89
Do not throw money at the purge valve, or anything else, for that matter.
Here's the list of suspects per the PC/ED:
There is a way to test the gas cap without any gear, but it's kind of gross. You stick the small end in your mouth, seal it with your lips and see if you can draw or blow air through it. It shouldn't pass air in either direction.
Econoline Pickup
1997 - 2003 F150
23
Jul 15, 2015 10:06 AM
lifted04xlt
Apr 10, 2009 11:25 AM
1984F15016
Jan 23, 2008 05:55 PM
bartamos
1997 - 2003 F150
17
Dec 13, 2006 03:16 PM
glennbobg
1997 - 2003 F150
Sep 9, 2004 11:13 AM
