Jacking Instructions
Old Aug 4, 2020 | 09:11 PM
obnxs250's Avatar
obnxs250
Question Jacking Instructions
Ok, I feel like a complete dummy here so please forgive my ignorance as this is my first classic vehicle, let alone a vehicle with the twin I beam suspension setup. How the heck do you jack the front end up and place a jack stand at the same time? Seems for me that either my jack is placed in the right spot but then I can't get a jack stand under the frame because the jack is in the way or when I finally get it positioned right the frame is so high in the air you'd need a 3 foot tall stand just to start with. I feel like I'm missing something obvious here as I've jacked up many cars over the years and worked on them without issue. Maybe I really just need taller jack stands?
Old Aug 4, 2020 | 10:42 PM
RichS2659's Avatar
RichS2659
There is a diagram with the jacking instructions on the glove box lid. But here you go for an owner's manual from 72:
https://www.fordification.com/librar...?/category/221
https://www.fordification.com/librar...0/category/221
Old Aug 4, 2020 | 10:45 PM
obnxs250's Avatar
obnxs250
Thank you for that, that will be helpful.
I got it done, just backwards. Jacked in the right spot on the beam but from behind the tire so I had room to put the stand under the frame in the front.
Old Aug 5, 2020 | 12:04 PM
351Cleveland C4's Avatar
351Cleveland C4
When I jack them up to rotate tires, I lift the rear first, and put jackstands under each side. Then i do the front, one side at a time with the jack.
Putting jackstands under the Ibeams can be done, but it's tricky, as you have to jack from a point closer to the center, and getting that right is trial and error to find the proper balance point where you also have enough room for a jackstand.
Old Aug 5, 2020 | 03:17 PM
'65Ford's Avatar
'65Ford
I've always placed the jack under the bolt under the coil springs. Then, if a jack stand is needed it goes under each respective i-beam as close to the jack as possible. If the i-beams need to be removed then wood blocking goes under the frame near the radius arm bracket.
I only use stands if the tires need to come off. Otherwise, I support any raised vehicle with solid wood blocks under the tires.
Old Aug 6, 2020 | 01:02 PM
351Cleveland C4
I've become fond of the ramps, if the wheels aren't coming off.
Old Aug 6, 2020 | 02:10 PM
obnxs250's Avatar
obnxs250
i see a set in my future for sure. But in those it’s a full brake job so off come the wheels!
Old Aug 6, 2020 | 07:40 PM
Jim-Pro's Avatar
Jim-Pro
I got a set of like this https://www.tractorsupply.com/tsc/pr...=jack%20stands
They work well for me. Easy and safe......
Old Aug 6, 2020 | 07:51 PM
obnxs250's Avatar
obnxs250
Thanks Jim-pro, those look very intriguing.
1970 Yeti
26
Nov 1, 2013 04:30 PM
hypophthalmus
Aug 21, 2012 12:45 AM
fergusonicford
Jan 27, 2008 08:33 PM
KeithE524
Jul 13, 2005 01:09 PM
joners
Dec 30, 2003 03:34 PM
