Sponsored by: Real Truck
Vacuum brake booster problems
Old Jul 7, 2020 | 03:27 PM
barnes80's Avatar
barnes80
Got my 06 f350 v10 running again finally. So far, the only problem is the brakes. I put a new vacuum booster and master cylinder on it with the new engine. After starting it, I have really hard brake pedal like there is no vacuum assist. I verified I have good vacuum and started checking things over to see if I missed something simple. Engine bay looks good, so I started checking out under the dash and noticed the rubber dust seal was sucked down tight. If I pull the boot away from the rod that connects to the brake pedal, braking action returns to normal. I already got rid of the old parts so I can't verify that way, but shouldn't there be a way for air to flow into that boot? I was going to poke a hole in it but figured I would get a second opinion.
monte97z
Apr 15, 2017 10:13 PM
hartski
Apr 28, 2009 07:36 PM
muckypaws
1978 - 1996 Big Bronco
Apr 16, 2009 11:59 PM
Matt Wilson
Aug 1, 2005 11:37 AM
