divorced 203 T-case info
Yes, it should come apart in sections just like the rest of the 203, simply with a closed input section. All you are interested in is the gear reduction section in the middle, octagon shaped. I can't rember who it is, but someone has a new kit that eliminates the longer adapter section to the 205, Check the BC bronco web page, I think that is where I found it. But if you are on a long wheel base vehical, the kit from the 203 to the 205 should cost about $500-700 depending on where you are located.
ya i figured that it was the same but i have not had a chance to brake it in half. i have seen plenty of chevy and a few fords 203 and they pretty much the same except for the bolting pattern, but the divorced model looks like the ford. i am going to use the ORD kit and tell them i need it for the ford 31 spline 205, thanks for the info, jason.
i have a ton of plow work coming in this week so no time to play, but i will crack it open soon and try to post up some pictures. by x-mas i hope to have the ORD double kit all hook up its going in my ****** jeep i know i know this is a ford site but if it help my DD is a 89 F-250 and its also my bread and butter truck so dont grill me to much, jason.
TheTowingCowboy
01-15-2012 09:51 PM
apachetech
02-06-2006 12:34 PM
