Flasher wiring help
Old Jun 25, 2020 | 02:43 PM
df85732's Avatar
df85732
Flasher wiring help
I can't remember which terminal the flasher wire is attached to. I have three options can someone help me out? ACC, AM, or Coil on the diagram? Also, do any of you know the amperage of of the fuse on the back of the light switch? It seems to have disappeared. LOL Thanks in advance. Dave
Old Jun 25, 2020 | 05:11 PM
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
The flasher goes on the "ACC" post.
I can't help you on the light switch fuse. My '53 didn't have one.
Edit: Here is a link to another FTE thread that shows it as 10 amp. I don't know if it's right, but he/she was pretty good with wiring.
https://www.ford-trucks.com/forums/1...ml#post9445430
Old Jun 25, 2020 | 05:35 PM
df85732's Avatar
df85732
Thumbs up
Edit: Here is a link to another FTE thread that shows it as 10 amp. I don't know it it's right, but he/she was pretty good with wiring.
Thanks! There is a slot for a fuse but I never remember removing one. No pictures or noth'n. I have been pretty good about that up to this point. I'll take a look at that thread.
Edit - I also failed to mention that I am still 6 volts.....think that makes a difference????????
Old Jun 25, 2020 | 06:45 PM
Harrier's Avatar
Harrier
I was thinking 10 amp as well, so since dan/julie mentions that as weill, I think you are safe.
It won't matter that you are 6 volts.
My light switch wiring diagram I posted in another of your wiring threads also shows ACC, so now you have two that agree with it.
Old Jun 25, 2020 | 08:10 PM
df85732's Avatar
df85732
Thanks Joe. I did look at it again. I must need thicker glasses! LOL
Old Jun 25, 2020 | 09:12 PM
Harrier's Avatar
Harrier
I just figured now that you are retired you are annoying your wife enough that she has been smacking you upside the head with a frying pan more than normal. She has your mind a little fuzzy
Old Jun 26, 2020 | 05:11 AM
JimG1098's Avatar
JimG1098
Julies. That sure was a strange case
2011FX2Crazy
2009 - 2014 F150
Oct 7, 2020 05:20 PM
Sickler1
Mar 9, 2020 06:26 AM
hello113
Oct 2, 2019 07:38 AM
Jake in PA
Mar 26, 2013 07:34 PM
clemet
1997 - 2003 F150
Dec 8, 2003 12:46 PM
