Engine suddenly runs rough
Old May 29, 2020 | 08:32 PM
Bill61's Avatar
Bill61
Every once in a while the engine acts like it looses a couple of cylinders. Then it goes back to normal. Recently I noticed that it does it every time I am backing up up hill. I think that must be causing it although it does it other times sometimes. Any ideas. 2006 F150.
Old May 30, 2020 | 08:47 AM
steve(ill)'s Avatar
steve(ill)
most missfires are caused by a bad COIL or old spark plugs... How old are the plugs ? No CODES show up on the dash ? Someone with a GOOD code reader might be able to narrow down which cylinder.
Old May 30, 2020 | 08:57 AM
Bill61's Avatar
Bill61
Could bad plugs cause a missfire that was intermittent? I don't know how old they are. I have had the truck for about 4 years and never changed them. I was thinking about buying the torque check app and the usb device to read the codes. Do you thing that is a very good code reader?
Old May 30, 2020 | 09:07 PM
steve(ill)'s Avatar
steve(ill)
yes bad plugs or coils can cause the problem.. I just have a GENERIC code reader that gives CODES that are SET... Some code readers can do real time data and see miss fires, etc............. that is what you need... I cant say for sure if Torque Pro does that.
stvneil
Large Truck
Nov 20, 2018 08:27 AM
kakita
2004 - 2008 F150
Jul 22, 2011 07:19 PM
dantsg
1997 - 2003 F150
Nov 2, 2008 06:45 PM
tetraruby
Aug 23, 2002 10:14 AM
