Major Headache
Old May 26, 2020 | 10:31 PM
Heavy_Duty's Avatar
Heavy_Duty
Major Headache
I have a 2001 F-250 with a 7.3. Driving home one day, the converter wasn't locking up in high gear. Then the truck mysteriously shut off and hasn't started since. I put a new ford cam position sensor in it. It had a code for the injector driver. Changed that still nothing. Thought maybe a computer. A buddy had one that was on the bench and worked in his truck when we tried it. (His truck is identical to mine except for paint color) No change. Hooked a scanner up. Passed a buzz test. IPR was at 40% duty cycle. ICP showed 2000 PSI during cranking. Pulled the valve covers and have oil flowing through the injectors as well. Wires all looked fine. Tonight, I pulled the IPR. Had some sludge. Replaced that as well. Still no start. What's next?
Old May 26, 2020 | 10:41 PM
BBslider001's Avatar
BBslider001
Google the "No Start Flow Chart". Also,read through the tech folder. Check your IPR and CPS pigtails. Check the IPR one closely. Make sure the insulation is intact and no wires are touching.
Old May 26, 2020 | 10:53 PM
BWST's Avatar
BWST
Got Data?
How is the fuel level and fuel pressure? Have the in-tank mods been done (hutch & harpoon)? Is there any smoke coming out the tailpipe during cranking?
Old May 26, 2020 | 11:31 PM
Heavy_Duty's Avatar
Heavy_Duty
Got a quarter tank of fuel. Getting white/grey smoke. Smells strong like fuel. No mods. I haven't done any fuel tank mods either.
Old May 27, 2020 | 08:00 AM
Listor's Avatar
Listor
best place to start, will help you walk through step by step!
https://www.ford-trucks.com/forums/a...6&d=1564895572
Old May 27, 2020 | 09:17 AM
Brian Hanks's Avatar
Brian Hanks
If you haven’t done hutch mod to fuel tank already you likely need more fuel in tank.
Old May 27, 2020 | 06:25 PM
Bonanza35's Avatar
Bonanza35
Dose the wait to start light come on?
Old May 27, 2020 | 06:39 PM
Heavy_Duty's Avatar
Heavy_Duty
Yes, the wait to start light comes on.
Old May 27, 2020 | 06:59 PM
bigb56's Avatar
bigb56
I second this, plus adding fuel is cheaper and easier than changing parts. If the pickup foot fell off it can't suck fuel below 1/4 tank
Old May 27, 2020 | 08:04 PM
97-psd's Avatar
97-psd
X3. This happens more than you think.
sbsmooth
Aug 19, 2019 02:35 PM
967.3zf5
Jun 19, 2016 04:14 PM
kcrb
Jun 2, 2014 06:45 AM
johnny diesel
16
Apr 24, 2014 09:02 AM
clkurz
Jan 27, 2013 01:42 PM
