Sequence of filter change?
Old May 26, 2020 | 08:58 PM
Dean06919's Avatar
Dean06919
1994 F350, SC, LB, 5.8L, C6, 4x4, 3.55 gearing.
I'm planning on replacing the oil pan gasket and timing cover gasket. The new oil pan gasket I bought is a one piece gasket. Which would you change first? Timing cover then oil pan, or oil pan then timing cover?
Old May 26, 2020 | 09:10 PM
timbersteel's Avatar
timbersteel
The oil pan has to be lowered some in order to pull the timing cover. I just did this on my '95 Eddie Bauer, 302, 4x4.
I would drop the pan, do timing cover, then gasket. Lots of crap wants to fall in when you pull the cover.
Old May 26, 2020 | 09:56 PM
GNR22's Avatar
GNR22
You can pull the timing cover without dropping the pan. You only have to remove the front 4 oil pan bolts and the timing cover will separate from it.
If you have a 1 piece oil pan gasket, you have to do the timing cover first, and then put the pan on. Otherwise you will have one hell of a time getting the timing cover back in place.
John89
Feb 7, 2020 11:51 AM
mike L
May 11, 2008 12:36 PM
Nightrain
Feb 6, 2007 07:10 AM
Torky2
Nov 21, 2006 06:14 PM
