Drivers side window switch...
Old Apr 3, 2020 | 03:58 PM
afonda's Avatar
afonda
Drivers window would not go up the other day for the first time ever... just my luck it rains on the drive home... anyway I pulled the switch, took it apart and all of the contacts were burnt with soot on them for all 4 window buttons. I was going to stop at just the drivers side window button because there were no issue with the other buttons... but, glad i pulled each button apart because they were all sooty and black on the inside. The hard part was pulling the actual buttons off. they are on there good. The way I got them off was with a flathead screwdriver right in the middle of the button by levering it up. I would say budget 2 hours... it is tedious... also the little lights do not come out as they are soldered into the switch, but they will bend enough to pull the switches out... Take you time and dont break anything. That white plastic thing with the lights in it is a real pain in the A$$.... careful cuz it will break.. trust me I know first hand. But it will bend enough to pull those little switch covers out which need to be pried up and out.
Old Apr 3, 2020 | 04:06 PM
F0rdc0wb0y's Avatar
F0rdc0wb0y
So, what was the problem here? Looks like you cleaned the contacts.
Old Apr 3, 2020 | 04:14 PM
afonda's Avatar
afonda
Yes. I did clean all the contacts. *** I'm guessing Ford is the F'n problem. Why all the soot? This is a stupid problem... new switch is probably $100 + ....
window works great now.
Old Apr 3, 2020 | 09:31 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
I paid $125 for the driver side Dorman part a few years ago. Individual switches are not available, just the cluster.
Old Apr 3, 2020 | 11:15 PM
pirschwagon's Avatar
pirschwagon
What you saw was Carbon. When an electrical contact is engaged there is a small arch present which produces Carbon. After a thousand activation, it does prevent contact from closing.
Old Apr 4, 2020 | 06:35 AM
FordTruckNoob's Avatar
FordTruckNoob
Wow. The switches on my 2000 are discrete. It would suck to have to replace the entire module if only one of the switches is acting up. Good thing this time was just sooty contacts.
Old Apr 4, 2020 | 07:13 AM
Listor's Avatar
Listor
I know you know you are right but i am telling you you are right SOOO you must indeed be right! LMAO my gosh i need to get back to work!
Old Apr 4, 2020 | 08:54 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Well done @afonda , I have added your instructions and helpful comments to the 7.3L PSD Tech Folder.
Old Apr 6, 2020 | 04:52 PM
afonda's Avatar
afonda
Just happy to help my friends...
ITOWAIR17
Mar 23, 2018 05:08 PM
hharris8
Dec 9, 2016 03:30 PM
v1uhoh
33
Jan 20, 2013 05:05 PM
thbowen
Mar 25, 2012 12:09 PM
themred65
Aug 17, 2010 12:24 PM
