phenolic carb adapter
Old Mar 9, 2020 | 09:18 PM
smle's Avatar
smle
78 F150 460. I have a 460 with stock manifold, trans-dapt adapter spread bore to straight bore holley. Is there anyone who makes a phenolic adapter to replace the aluminum adapter?
I have searched and came up empty.
Old Mar 9, 2020 | 11:10 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Jegs, Summit Racing and or Speedway?
Old Mar 9, 2020 | 11:20 PM
smle's Avatar
smle
No go on Jegs or Summit. Didn't think of Speedway.
Old Mar 9, 2020 | 11:22 PM
77&79F250's Avatar
77&79F250
Also think stock car guy or local hot rod performance shop?
https://www.holley.com/products/fuel...s_and_spacers/
https://motorsportsofkc.com/browse?c...118281&page=11
https://www.google.com/search?q=phen...h=718&dpr=1.75
Old Mar 9, 2020 | 11:31 PM
smle's Avatar
smle
No real performance shops in the Mountain Home area, also did a google search with the same result. Will check out the others though.
Old Mar 9, 2020 | 11:38 PM
77&79F250's Avatar
77&79F250
Get a block of phenolic material and bust out some wood shop skills.
Mr Gasket site?
Old Mar 9, 2020 | 11:42 PM
77&79F250's Avatar
77&79F250
Carb Adapters
Good 460 info forum https://www.460ford.com/threads/4300...needed.162999/
Old Mar 10, 2020 | 03:34 PM
smle's Avatar
smle
In trying to cure my problem (vapor locking) is going to be either Mr. Gasket 3710 or 97. The 3710 is stacked gaskets with heat shield. The 97 is stacked gaskets and called heat dissipater.
Anyone have any opinions.
Old Mar 10, 2020 | 05:22 PM
matthewq4b's Avatar
matthewq4b
Are you getting vapour locking in the carb or fuel lines ?
Old Mar 10, 2020 | 05:27 PM
smle's Avatar
smle
In the carb, seems to boiling the gas out. Fuel filter has gas in it.
Old Mar 10, 2020 | 05:52 PM
i-w's Avatar
i-w
Canton makes some as well
https://www.cantonracingproducts.com...query=phenolic
Old Mar 10, 2020 | 06:13 PM
matthewq4b's Avatar
matthewq4b
You are getting fuel boiling due to the ethanol content in the fuel, modern fuels are much lighter (in terms of heavy hydrocarbon chains) and the addition of ethanol compounds the problem further.
So you can fix this 2 ways insulated the carb from engine heat Phenolic spacers or more fibre spacers or the addition of a heat shield such as this. https://www.summitracing.com/parts/hly-108-70
The other solution is to add about a gallon of diesel to a tank for fuel, doing this will add in heavier hydrocarbon chains and lower the boiling point of the fuel. This is a common and easy solution that works for most people. Using Diesel also does not affect the octane rating of the fuel.
Old Mar 10, 2020 | 06:19 PM
smle's Avatar
smle
I might be to picky, but they didn't have what I was really looking for.
Old Mar 10, 2020 | 06:29 PM
smle's Avatar
smle
I've been running premium in it since I got it running. I would try and modify the Ford 4350 phenolic spacer if it had more material underneath.
Old Mar 10, 2020 | 07:29 PM
77&79F250's Avatar
77&79F250
I fought fuel boil/vapor lock with my Bronco for a while, ended up stacking a old Ford 2bbl EGR plate on top of the Mr gasket adapter. And insulated the fuel lines.
