Pitman Arm Installation
Old Feb 21, 2020 | 10:28 PM
rpaxton939's Avatar
rpaxton939
I am installing a CPP 400 power steering gearbox from Mid Fifty with a new Pitman Arm that is part of the kit. The steering box shaft end of the Pitman Arm is 1" thick. I can only get the Pitman Arm on the gearbox shaft about 5/8". This leaves about 3/8" left if it should be installed the full 1" thickness. The lock washer is fully seated behind the nut and the nut is completely threaded onto the shaft. Should the Pitman Arm be fully driven onto the gearbox shaft or am I ok with the 5/8"?
If it should be fully driven onto the gearbox shaft, what is the best way to get is done?
Old Feb 22, 2020 | 02:10 AM
rico56's Avatar
rico56
Normally I’d say the pitman arm should be fully driven onto the shaft of the gearbox, but if you got the washer mounted and the nut is fully onto the shaft, that can work too. How is the alignment of the pitman arm in comparison to the original setup? Was the old pitman arm closer to the frame?
When you done with the conversion let me know how it went and how it works, I’m planning to do the same conversion with the same kit.
Old Feb 22, 2020 | 07:50 AM
moejr's Avatar
moejr
I had the same issue when installing my upgrade, so far no problems after 3 years of use.
Old Feb 22, 2020 | 09:00 AM
rpaxton939's Avatar
rpaxton939
I would be happier if I could gain even a 1/4" more. As far as the previous pitman arm/shaft depth, it was seated closer to the frame but that was a different pitman arm and gearbox. I wonder if I took it off of the shaft and put a slight coat of grease on the splines if that would help or not. I don't know if that is the right thing to do.
moejr.....How far onto the gearbox shaft did you get the pitman arm?
Old Feb 22, 2020 | 09:14 AM
rico56's Avatar
rico56
I doubt that putting grease on the splines will give you that 1/4“. Do you have a picture how it looks right now?
Old Feb 22, 2020 | 11:42 AM
moejr's Avatar
moejr
Nut is just about flush, I tighten it as far as it would go and seems to be holding up ok.
Old Feb 22, 2020 | 01:14 PM
rico56's Avatar
rico56
I’d leave it as it is, but I’d use some loctite just to be save. If you don’t mind, you can send me some pics of the installed kit since I’m planning to install the same kit in my ‘56 F100
Old Feb 22, 2020 | 02:37 PM
moejr's Avatar
moejr
My truck is a 49F1..... the kit I used came from Summit part # CPP5356PSKOC made for the 54-56 F100. I had to re-drill holes in the frame to mount the box. Not sure what modifications are needed (if any) for the 56 F100 install but I'm guessing it's a direct fit.
Old Feb 22, 2020 | 03:06 PM
rpaxton939's Avatar
rpaxton939
The splines shown are about 3/8" between the pitman arm and the truck frame.
The second picture shows the nut on the front of the pitman arm. Looks like how yours is. It seems plenty secure but would be nice if it was run in the total distance.
My frame was already redrilled because someone in the past replaced the original gearbox #3C _ _ _ with one from a larger truck #4C0007. (That information I got from bigwin56f100 who supplied me with a steering shaft a couple of days ago.)
Old Feb 23, 2020 | 06:00 AM
Indybeer's Avatar
Indybeer
I didn't use the gearbox from Mid Fifty, but i did use their Pitman arm. I have plenty of thread extending thru arm.
Old Feb 23, 2020 | 08:05 AM
rpaxton939's Avatar
rpaxton939
Did the pitman arm slide onto the splines fairly easily or did you have to drive it on before you put the washer and nut on?
The threads showing on your installation is about what I expected to see on mine. I don't know why it doesn't want to go all the way up the shaft.
Maybe Mid Fifty sent the wrong pitman arm. I will have to call them tomorrow.
Old Feb 23, 2020 | 09:29 AM
Indybeer's Avatar
Indybeer
It slid on most of the way without beating it. Then I just tightened it down to seat it on the shaft. The shaft for the CPP 400 gear boxes might not be a long as an original Toyota gearbox.
Old Feb 23, 2020 | 10:24 AM
raytasch's Avatar
raytasch
Believe Nothing
Bob, I would remove that arm. Wrap a piece of paper around the shaft and reinstall the arm. Tighten the arm to specs and then remove. If the impression left by compressing the arm onto the shaft are nearly even the full length of the imprinted part of the paper, you should be good to go. Upon final assembly, when you're certain it is where you want it, I would either lightly "stake" the end of the shaft or use locktight.
Damn, I miss getting together with you for our BS and discussion sessions.
Old Feb 23, 2020 | 02:54 PM
rpaxton939's Avatar
rpaxton939
The CPP shaft must be pretty close to the Toyota because I still have 3/8" behind the arm.
Old Feb 23, 2020 | 02:56 PM
rpaxton939's Avatar
rpaxton939
Ray, I will try your idea but first I will call Mid Fifty about t tomorrow. And yes, we have to get together for some of that BS.
