98 E350 Aftermarket RKE Installation Question
Just purchased a 98 E350 Extended Club Wagon V10. It has power door locks installed, they work fine. Would like to add remote keyless entry. I do not find the module behind the B pillar as others have suggested. Has anyone added an aftermarket keyless entry system, if so, which one and where did you connect the wires on the vehicle? I see online these systems are pretty cheap. I would like to open the doors with a remote instead of using a key all the time. Not interested in the alarm/siren stuff. Thanks for the help.
Most every aftermarket alarm can have the siren and alert function disabled when the door lock/unlock function is actuated. Don't limit your search for a good inexpensive device due what it has, look for how only the features you want can be enabled.
You'd be SOL trying to add a factory RKE to a vehicle not originally equipped with that system. Its unnecessarily complicated and too prone to failure of the RKE module---going the aftermarket route is the least expensive and easiest to add on.
I've done that on two different E-Series, one with and one without the factory RKE.
Where do you intend or want to mount the alarm's "brain"?
I've always mounted my alarm "brain" somewhere just behind the Lt B-PIllar---there's always on fused power available in a few connectors as well as giving you the option to tap into the chassis PDL's.
I would utilize a 5-wire reversal (rest at ground) circuit to help isolate the alarm from the chassis wiring through relays--the schematic is like this:
Wire colors may vary which isn't important as making the correct connections. Whatever alarm you'll be using should have a similar schematic included with the installation instructions.
I do have the schematics from a Mitchell’s manual. My confusion is coming from the fact that there are two versions, one “with memory lock module and one without”. The colors of wires I find in the rear door match the “with memory”. However, it also shows the power door lock module behind the B pillar, I took off the side panel behind the pillar and the panel covering the seat belt retractor and I didn’t see any boxes. The schematic “without memory” wire colors are different. If I could find the box behind the pillar, that’s where I’d wire a remote system, easy peasy. I do not know what it means by “with memory”. The owners manual is no clue either. Hate to do it, but sounds like I need to pull the panel again and look better. I thought it would be readily visible, is that not true?. No garage and living on the Oregon Coast, we are in the monsoon season. 150 inches of rain a year and 60 of that is in Jan and Feb. I do appreciate all the advice.
Saying again IF you don't hare RKE there's no module or any other device you'd see--your year simply had the most basic of PDL wiring circuits especially without the factory RKE. You were directed towards the driver's side base of the B-Pillar as that's where most of the wiring found aft of the front seats is found, easily enough to tap into the PDL's in that location IF your alarm "brain" will be somewhere close by.
You need to find a schematic for your year---try the electrical and wiring sub-forum here on FTE. I looked on eBay for what's called an EVTM or book of wiring diagrams but there's nothing for your year. You MIGHT luck out with something as late as 2000 but I'd not count on it being that helpful. Ford is good about changing things electrically so even though the circuits all work the same connector pin outs and wire colors will change from year to year.
Again there's no module for your PDL's whether it has RKE or not.
I am following this with interest. I have a 99. The RKE has failed (I know this because I had it connected and with slight pressure on the PCB various things would go off). I wanted to find an aftermarket RKE to "plug" into the existing wiring harness. Looking for (a) recommendations on the aftermarket unit, and (b) wiring diagrams that will explain how the existing system functions. Also, it seems some of the aftermarket units don't have their own relays on the PCB, so you have to install relays separately. The Ford RKE does have relays (six of them). So, to keep things simple I'd like an aftermarket unit with relays built in.
So, if the OP or any of the others posting here could supplement with that information, I know I would appreciate it. I imagine that there are several of us lurking here would would like to know this information.
Thanks.
Thanks.
