1988 Ford F-150 manual transmission battery and starter cable wiring schematic
I bought this truck from someone wrecked and missing several parts within the engine compartment and have slowly been putting it back together and I have no idea where to connect the cables or how to connect them that are coming from the starter please can someone help me
This is the starter I have
This is the starter solenoid I have
No that doesn't really help. There are two cables attached to the starter one of the cables is attached with the bolt that holds the starter on to the vehicle and the other cable is bolted on to the starter itself and I don't know which cable is positive and which is negative and how to go about connecting them to the battery I have red stuff about one of the cables connecting to the fender also and also to the engine block and then I don't know if they connect to the battery itself or to the starter solenoid from there
The cable that connects to the starter goes up to the solenoid on the passenger side fender on one of the large bolts. That is the only cable that goes on that bolt.
The cable that goes on with the mounting bolt is just a ground cable. I'm not quite sure of the best place to attach the other end of that cable. How long is that cable that goes on with the mounting bolt? Also what kind of end is on the other side of that cable?
Heavenword1
07-14-2013 09:51 PM
PotomacEd
07-25-2006 01:36 PM
