Superduty tips and tricks, it's the little things.
Wanted to post all the tips, tricks & little things that these trucks can do that all may not be familiar with. Forscan doesn't count because that's a different animal.
1. If remote battery dies you can start truck (w/ pushbutton) by putting key in slot next to cupholder.
2.with keypad on door, hold 7-8 & 9-0 to lock doors.
3. Open tailgate with door keypad (if equippd) enter code then press 5-6.
4. If not sitting in truck you can start (with fob present) by holding start button for approx. 3 seconds.
#1 you can roll down your windows from the remote by pressing unlock and then pressing and holding unlock.
#2 the alarm system has motion sensors that will alert if someone tries to reach in the cab even if the windows are down.
#3 you can turn the truck off and retain use of the sync system until you open the door (or some absurd amount of time), useful when finishing a conversation but you don't want to idle in your driveway.
Some random ones
Can turn the radio/sync system on without accessory mode on both push button and keyed trucks. Just press power. Doors can be open.
Can update to have single stage unlock (press unlock once unlocks all doors, same for keypad without need to press 3 after code) from cluster menu.
There is a console located under the center jump seat on 40/20/40 trucks and the "dead key/programming" slot can be found at the rear. Still amazed me how many don't know there is a second console under the seat.
New door codes can be programmed through sync or the keypad.
2) A kid at the car wash showed me that my truck has power fold mirrors. I had been folding and unfolding them manually.
I know on my 2016 key fob, if I press and hold the unlock button lowers the front windows. It's great in the summer when you want to vent the truck before getting in. Yes I have remote start but still it's nice cause that first burst of heat is dissipated.
Someone already pointed this out.
Here's a pretty good document that describes the things above and a whole lot more.
