Windshield wiper/washer frustration
Old Jan 22, 2020 | 09:24 PM
JoeVH's Avatar
JoeVH
My 2017 F350 came with what I would call "solid" plastic framed windshield wipers, like some versions of "winter wipers", as opposed to the older metal framed style. Whenever I use the washer motor and wipers, it leaves a puddle of wiper fluid around the left side of the driver's wiper, which then works its way up the windshield as you're driving and makes a mess of your windshield unless you keep intermittently activating the wipers several times over the next couple minutes. Does anyone else experience this? Would a different style wiper help? Has anyone found a fix to this? Something about this aerodynamic design is not right.
Old Jan 22, 2020 | 09:57 PM
TeddyD's Avatar
TeddyD
What you describe is normal for me too. No matter what I do, if driving at higher speeds, I always have a little splash or residual washer fluid running up the window. I think it’s just a design flaw and I have learned to live with it.
Old Jan 23, 2020 | 03:19 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
I don't notice it on mine. But I use Rain-X washer fluid, so anything left just slides right up and off
Old Jan 23, 2020 | 04:52 AM
Heathmc's Avatar
Heathmc
Have you tried activating the courtesy wipe? It adds a single wipe after a ~10 sec delay of using the windshield wipers. This cleans my windshield of most if not all residual water.
Old Jan 23, 2020 | 07:37 AM
harmanrk's Avatar
harmanrk
The style of beam is not going to help. On the last stroke, the passenger blade goes up, and pushes all the water to the middle of the windshield. The driver side wiper then comes down and collects this (or at least what is not blown off the top, which will depend on vehicle speed). Some water is then trapped under the drivers side blade, and overtime the wind will move it to either the passenger or drivers side of the blade. Happens on every car I have ever seen, except those with wipers that tuck into the cowl (no wind to push the water out), or where the passenger wiper pivots my the A pillar rather than center of the hood.
Old Jan 23, 2020 | 08:10 AM
crewzer's Avatar
crewzer
+1 for the courtesy wipe function!
Safe travels,
Jim / crewzer
Bohen
6.7L Power Stroke Diesel
Oct 18, 2019 10:45 AM
BowtieConvert
Jan 14, 2018 10:51 AM
mwillmont
Oct 3, 2017 12:04 PM
mtntop1
Aftermarket Products
13
Feb 17, 2015 09:57 AM
FlaresideF150
Sep 25, 2012 11:26 AM
