Road noise
Old Jan 9, 2020 | 12:22 AM
portsample's Avatar
portsample
Road noise
It seems that road noise is getting louder in my rig. Especially on washboard roads, or roads with ice ridges. Noise seems to be centered in the left front area. Ball joints were replaced 50,000 miles ago and still feel tight. I replaced the front shocks a few months ago. Jacking the front up and manipulating the tires to identify play is not productive. Truck has 200,000 miles on mostly paved road.
Questions: What bushings up front are generally the first to wear out? Is there anything else I should be looking at? Thanks in advance.
Old Jan 9, 2020 | 05:28 AM
FordTruckNoob's Avatar
FordTruckNoob
I don't know which bushing wears out first but you might as well replace all of them while you have the front end apart. I used these on mine and the front end quietened quite a bit.
Energy Suspension 4.2148G Front...
Amazon Amazon
Energy Suspension 4.5186G 32mm...
Amazon Amazon
Also check your cab mounts.
Old Jan 9, 2020 | 05:38 AM
Tugly's Avatar
Tugly
Have you inspected all of your sway bar bushings?
Old Jan 9, 2020 | 10:16 AM
portsample's Avatar
portsample
Only superficially and by trying to manually move them to assess play. All "seems" fairly tight.
However after 200,000 miles I'm sure the bushing material has seen a reduction in elasticity.
Old Jan 9, 2020 | 10:19 AM
portsample's Avatar
portsample
Energy Suspension 4.2148G Front... https://www.amazon.com/dp/B001662WDA...p_mob_ap_share
Energy Suspension 4.5186G 32mm... https://www.amazon.com/dp/B000CNB2BQ...p_mob_ap_share
Roger on all this. Leaf spring bushings have been high on my list of suspects. Thanks.
Old Jan 9, 2020 | 10:23 AM
helifixer's Avatar
helifixer
sagging body mounts can let stuff rub that didn't used to.
Old Jan 9, 2020 | 12:20 PM
FordTruckNoob
I forgot to inlude these.
Energy Suspension 4.7126G Front...
Amazon Amazon
Old Jan 9, 2020 | 12:44 PM
portsample's Avatar
portsample
Thanks. I may do a deep dive in the spring and replace them all. My money is on the leaf spring bushings.
Old Jan 9, 2020 | 03:19 PM
renoduckman's Avatar
renoduckman
This.
Sway bar end link was causing this on my 02. It was obvious when I looked at it.
Old Jan 10, 2020 | 05:52 AM
Tugly's Avatar
Tugly
Just for info: When I bought Frankenstinky, the driver-side sway bar link was missing the bolt. Inoperable. Just sittin' there. Horrific pupil-dilating cornering. fixed it.
Old Jan 10, 2020 | 09:47 AM
portsample's Avatar
portsample
Thanks. All good info. I'm going to replace sway bushings and link arms this weekend and see what that does. Time to replace them anyway.
Old Jan 10, 2020 | 02:18 PM
Brian Hanks's Avatar
Brian Hanks
What he said. I put new shocks on mine and helped a ton but still has banging when over bumps. My drag links were badly worn and it was a new truck after I replaced them. The swaybar bushings are older but still in good condition. I will probably replace them next prophylactically this year.
Old Jan 11, 2020 | 09:35 PM
portsample's Avatar
portsample
Okay, replaced sway bar bushings and end links today. Bushings were probably okay, links were definitely tired. Seems to have improved things a little. Greased ball joints and this helped somewhat. Test drives were short. Thanks for the help and input.
gpeade
Aug 12, 2019 08:38 PM
jstihl
Dec 28, 2017 08:32 PM
Flying Finn
Feb 24, 2011 12:46 PM
Shade
Jan 20, 2010 09:12 AM
mainecorrado
Apr 6, 2006 12:39 AM
