Engine swap direction advice
What engine would you put in it? I have welders, a plasma cutter and I can get things fabricated. New mounts or cross members wouldnt be a huge problem. What I DONT want is a modular engine. Yes the coyote is nice. Yes it makes power....I do not want a non-conventional engine. Im not against fuel injection. Im against over head cams. I have a Ford Taurus rotting in my yard because of the overhead cam. No thanks.
I thought about a 5.0 HO. They sound good with a cam and exhaust. Descent power and a great aftermarket. Maybe a 351? Nice power, good aftermarket. Doesnt sound as good cammed as a 302, but still nice. Some go with the FE engines. Im not even against an LS1 swap (gasp) Any advice? Just wondering what to keep an eye out for, and what to avoid.
For me, it had to be an FE. I went the stroker direction and have a 445 that pleases me, but it is what I wanted. 302, 351, and modern engines are all fine, but that old FE magic speaks to me. Good enough to win LeMans 4 times, good enough for me.
I can make that with a 302, and a 351 as well as a slew of others. Im new to Fords so Im familiar with the 2 different 351s, and obviuosly the 5.0 HO and the FE engines, but only a little. I was driving age when the Fox bodies came out, and had a friend in the Army who had one that went 11.20s, and that was in 1993. That car, and about half the other fox bodies just sounded so good, with the flowmasters and a huge cam. I was into the formula Firebirds. Irocs, and GNs also roamed the streets back then. It was a good time, and a 15 second car was average. Then came the ZR1 and the Viper, the Syclone, Impala SS, Saleen mustangs, Cobra Mustangs.....Those were the days...
Anyway, Im open to an easy way to make 400 HP. Someone will surely ask: "at the crank or the wheel?". And honestly I dont think it matters. I wont dyno the truck, or race it. Im going to build it and drive it and use it like a truck. I will lower it, and upgrade the suspension and brakes and interior. Some wheels and tires and itll be done till I get bored of it.
What I've come back to is that I like the FE 352 in this truck. It runs well, very smooth, quiet. Starts well and is just pleasant to drive. This is my third 1967 with an FE 352. I even have considered making this 352 into a 390. But I just couldn't tell myself there was anything wrong with the 352 as it is. So at this point, I'll be keeping it and just doing a mild rebuild. Not trying to make it a 360 or 390. Not increasing stroke. Just rebuilding it as if it was a brand new 352. This may mean one size up in pistons and have to get these custome made. That's fine.
I just can't find anything wrong with this engine if I consider the way I'm using it. Driving arond town, towing a small sail boat, and camping trips. The only thing that comes up for me is getting it to burn as cleanly as possible. The least amount of emissions is important, more than power and torque. So I'm trying to figure out what else I can do to lower emissions but still keep the stock 352.
The other thing that comes up is noise and comfort at highway speeds. 60 mph is just fine. 70 mph is just slightly over smooth, quiet, efficient. So I have been considering an overdrive transmission, like the NV4500. But even that I'm not sure about as it does change where the stick is inside the truck and I don't really want to do that. Maybe the Tremec transmission won't do that as it has different locations for shifting. Still walking through that.
Bottom line, the FE 352 engine is what I'm sticking with. It looks good, runs goods, has plenty of power and torque. I'm keeping the same 2 barrel autolite 2100 carb as it works fine when turned. Keeping the stock manifolds. I'm not sure about changing to electronic points yet, as these have not been a problem in the past.
I decided not to think what to do by comparing to newer technology. Honestly, I'd rather just go buy a Toyota if I wanted that. Instead I just look at the engine I have and ask is this working for me? And nothing comes to mind that is wrong with the FE 352.
And I like how it looks under the hood.
Here is a picture of a redone 352, this is not my truck but what I'm after. I have exactly this same airclearer, emissions, power steering, and booster.
They are pretty cheap and plentiful out of Van's and pickups. Grab a good used shortblock or rebuilt can he had for around $1200
You can make good power from a 352 or a 390 with iron heads, but you need to do some research on what heads are best, and what intake, and get ready to do some porting. Two books to buy if you go the FE route - Barry Rabotnik's "How to Build Max Performance Ford FE Engines" and available on Amazon, and Jay Brown's "The Great FE Intake Comparo", available on the FEpower.net site. In fact, if you go the FE route, join the FEpower.net forum, you will be astonished at the quality of advice you will get.
If you go the SBF or modern engine route I'm sure you will also wind up with a good engine.
