Shift Points for 6.9
Old Dec 18, 2019 | 01:25 PM
Ed H's Avatar
Ed H
I have been wanting to install a tach on my '84.
Are there recommended shift points for the 6.9? The owners manual lists them for the gas burners for each trans but nothing for the diesel. The supplement diesel manual says nothing pertaining to this.
Also what are the fast and slow idle speeds.
No need to install a tach just to watch the needle move.
All the info on my truck should be in my signature.
Thanks in advance,
Ed
Old Dec 18, 2019 | 03:49 PM
hairyboxnoogle's Avatar
hairyboxnoogle
No recommended per se that im aware of, peak torque is 1400, peak horsepower is 3000. Low idle is 750, high idle is 3600 no load, 3300 loaded. Normal driving i shift around 2k, loaded or "spririted" 3k, depending on what i need. I wouldnt load the engine excessively under 1200 rpm. Hope i answered some of your questions. As far as BSFC ive looked, never found much, but imo they get the best mileage running 1600-1800rpm or 2600-3k. I personally never get good mileage running in the middle, with either of my IDIs
Old Dec 20, 2019 | 09:34 PM
SchaefferUSMC's Avatar
SchaefferUSMC
High idle 3600, dang, truck would be screaming to warm up. Im assuming you were talking red line.
Old Dec 20, 2019 | 09:57 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
No he was correct High Idle is where the IP is against the Governor..... this is Called High Idle by Stanadyne.
There is a Cold Idle solenoid on the outside of the pump that can be adjusted ... and there is a Cold Advance solenoid inside the Pump that you really cannot adjust.
Anyway Cold Idle can be set between 900 and 1200 RPM. I normally go for 1000 RPM
Old Dec 21, 2019 | 02:23 AM
hairyboxnoogle
Redline is 3700 rpm
Old Dec 21, 2019 | 11:17 AM
SchaefferUSMC
Hmm, I knew there's a reason I read these forums.
CA-F250
6.7L Power Stroke Diesel
Nov 18, 2012 07:22 PM
Crazy2
20
Dec 23, 2011 11:08 PM
chubyboy
Apr 4, 2009 11:32 PM
Mike F250
Mar 17, 2007 09:22 AM
Wells
Dec 18, 2006 06:49 PM
