Headlight Fuse Block
I checked the circuits with a test light and while there is power to the headlight switch, there is no power on the rear of front parking lights terminal on the switch. I was reading my manual and it shows a fuse block on top (or bottom) of the headlight switch. I do not have a fuse block on my switch. The old one had it but neither of my two new ones (LMC and Dennis Carpenter) did. The new harness has a complete fuse block for the entire harness,
Question #1. Do I need a fuse block on the headlight switch?
Question #2. Do ii need to run a separate ground wire from the headlight switch to a chassis/frame ground?
Any help would be appreciated, I'm pulling what little hair I have left out because of this.
It might even have been mandated for safety reasons.
But it can't hurt either, since the switch was originally mounted in a metal dash anyway, simply making sure it's grounded does not hurt anything.
It's always good practice to make sure that the dash panel itself is well grounded to the rest of the body. Helps the gauges and any other stuff that needs grounds work better. Also helps reduce radio noise.
Regarding the grounding of the switch itself, I really am not that familiar with the older switches to know whether or not there is the requirement of a ground. Just going on what I know about later switches ('66 and later mostly) but if it grounded through the dash before, it should still do so without you adding a ground jumper. Wouldn't know where to attach it anyway!
If you freshly painted the dash, or it's totally rusty on the back though, I would attempt to clean that up so that the switch has a good contact point with the grounded dash.
Just FYI the main ignition switch is usually grounded. Has nothing to do with the accessories working, as those are still the standard "pass-through" circuits where the switch is just there to open and close the circuit. But most switches back then had what was called the "prove out" or "proof out" circuit activated in the START position. This circuit grounded to the dash as a method of checking function. Was often used for stuff like the brake warning lamps in later vehicles as an old-school way of testing the lamp at each startup.
But as said, the light switch does not normally need a ground. Maybe for the rheostat for the dash lights? Dunno but someone will.
Good luck.
Paul
If power is going in, but not going out when it's supposed to, then the only thing it could be in my mind is the switch itself.
Of course, that doesn't mean I'm right! Just means it's one of the possibilities higher up on the list hopefully.
After all, finding a bad switch and getting a new one will help you keep some of your hair!
Paul
I remember well when you could just assume that the new parts you installed were not the problem. Now as often as not they ARE the problem or create new ones!
I have not looked at any diagrams to see if there is something funny about how the switches are laid out in this vintage of truck, but I wouldn't thing they're so different that you can't use the test methods you've been using. If you don't get power out on the terminal, it should mean that in fact something is wrong inside the switch. You know power is going in, it's just not coming out. Crappy way to find out about modern parts!
Anyway, curious to know if they were both the same brand. I'm getting to the point that I'd like to see everyone mark each defective part so that when you go to the same place to get a replacement part, you're not just buying someone's old mess that never got sent back to the manufacturer.
Seen that happen too, but hopefully it's not too widespread.
Good luck on the third.
Paul
We had the same issues on traffic signals, when LEDS first came out. Because there isn't enough load it doesn't make a complete circuit. We would install a resistor or another bulb inline, which would solve the issue.
-The bulbs all light for the turn signals and hazards so the wiring must be okay.
-The circuit requires a wire from the fuse block to post D1 on the switch. The wiring harness instruction say to simply run a wire from d1 to the door switches/lights and back to D2. It specifically said the white wire from the fuse block(#45) in the kit was not needed leading me to think the power for the dome light was coming internally from post B of the switch..
-Posts D1, R, and P all would not light the test light meaning they were not getting any power from post B because it was hot therefore there had to be another power wire for the switch.
- Back to EricJ's comment made me do a quick check with the white wire on post D1 and the parking lights and dome light lit immediately. Now I have two extra headlight switches, parking lights and a dome light.
Thanks to all the comments. I know sometimes I worry that my comments might not be right or worth mentioning. ALL comments are good and could end up fixing the problem.
Oh, but in a "by the way" kind of way, just because the hazard, turn signal and brake lights work, does NOT mean that the wires are good. Just means that those wires work.
These are separate circuits between the bright filament (brakes and signals) and dim filaments (running/parking lights) from the switch to the lamps. So separate wires all the way from the switch to the area of the bulbs, where they might split off to power the different lamp locations in that corner.
Glad you did some more digging and found the issue. A big win!
Paul
