1997 F250 crewcab with the 40/20/40 seats.
Would like to find a firmer/ egronamic seat to support my arthritic hip. Looking for options to bolt onto the existing frame that goes accross all the seats.
My Honda CRV 2003 seat with a simple manual rail system looks promising.
Looked at used truck dealer's 2017 lariat seat, but it appears to bolt to the floor. Not an option with my standard frame.
Any input would be appreciated.
Thanks, Bob
If you want a 100% bolt in option, try and find a western hauler or Centurion that you can rob the seats out of. Otherwise, you could take your current seats to an upholstery shop to get them redone.
If you want to do a little fab, any newer model seats will go in, you'd just need to fab some brackets and drill some holes.
Will do more research on newer model seats & check for avaliblity and price at local salvage yards.
I will see if the bottom seat foam can be replace on my current ones too.
Currently added cardboard sheets under my seat covers to get rid of the sag. Not the best thou.
When I did my seat I got bottom foam seat for a 99-2000 and put it in
my seat. I was admonished for doing it by some but it has worked well for me and I would do it again. At the time I got the foam cushion from e-bay for about $100.
If it worked, why were you admonished?
Thanks for the tip.
