1997 7.3
Old Dec 4, 2019 | 06:59 PM
joesch1999's Avatar
joesch1999
Before replacing Glow Pugs and new valve cover gasket truck would start and run. I did however wash the engine while it was running. Before I replaced the glow plugs for obvious reasons. This truck has 480,000 miles. It tries to start but just hits and smokes. I did buy the zd11 glow plugs. When I say smokes it smokes like a freight train while trying to start the truck. Any suggestions? Btw no codes , hooked up my snap on Modis edge.
Old Dec 4, 2019 | 07:11 PM
Hit Man X's Avatar
Hit Man X
Thumbs up
Glow plug relay good?
What is the CCA of the batts and where are you located with the temp when cranking? My beat *** engine starts down to mid 20F (lowest been around here lately) without being plugged in to the wall.
Old Dec 4, 2019 | 09:06 PM
joesch1999's Avatar
joesch1999
Relay is good , temp is 45 , batt are 850’s new, I’m in southern il
Old Dec 4, 2019 | 09:37 PM
z31freakify's Avatar
z31freakify
Just to be safe, ark the two big post on the GPR for 30 seconds and try to start it again.
blow dry the ICP sensor and connector as well as the IPR.
Old Dec 5, 2019 | 06:46 AM
joesch1999's Avatar
joesch1999
thanks I will try that. I have hooked a test light to it already it stays on for about 2 min. Wouldn’t the scanner pick up if the sensors were bad?
Old Dec 5, 2019 | 02:33 PM
Hit Man X's Avatar
Hit Man X
Thumbs up
Scanner will not tell you what a problem is, you must understand the data. Then test the sensor in question accordingly.
https://redirect.viglink.com/?format...20flow%20chart
It could simply not be turning over fast enough if the starter is old.
Old Dec 5, 2019 | 04:56 PM
z31freakify
Wahsing the engine always leads to trouble with sensors that have the seal compromised. Blow dry those sensors and anything electrical.
Old Dec 5, 2019 | 07:40 PM
joesch1999's Avatar
joesch1999
Scanner brought up intermittent cam sensor
I replaced sensor and the pigtail with factory ford sensor . Still won’t start still has the same code. I’m guessin the wiring will have to be gone through unless someone points me in a different direction.
Old Dec 7, 2019 | 04:31 PM
joesch1999's Avatar
joesch1999
Engine is Running
I had to unhook passenger side back injector to get engine to stay running.
Any Ideas , keep in mind I replaced the glow plugs and valve cover gasket
Old Dec 7, 2019 | 04:47 PM
z31freakify
Maybe one of the wires is crushed between the vc and head. Check that out. Ohm the injectors and GP, .8-1.0 on the glow plugs and 3. something on the injectors just search on the stickies.
Old Apr 21, 2020 | 07:32 PM
joesch1999's Avatar
joesch1999
Smoking , injector tip broke off in cylinder
Replaced injector and injector cup. I was told that when a injector tip breaks off, it always puts a hole in the piston. Although I don’t have any fuel in the oil after I changed it.
When the injector tip broke off I had flames coming out of the exhaust and the o rings on the injector burnt off and that’s where all the fuel came from.
After the oil change and replacing the injector and injector cup I have no diesel in the oil.
My question is if the piston had a hole in it, wouldn’t diesel get in the oil?
Wouldn’t this be more of a head gasket being blown?
dirtman48
34
Dec 4, 2014 10:12 AM
TraderJoe43
Apr 2, 2014 11:19 AM
vfelix702
Jan 13, 2011 07:04 PM
PoWeRsTrOkEdF250
Oct 4, 2006 02:18 PM
MDB
30
Jan 8, 2005 03:23 PM
