Help
Old Nov 28, 2019 | 06:06 PM
BobbyLC's Avatar
BobbyLC
Help
Where is the fuse for the glow plugs Found at in a 99 F 550 7.3 power stroke
Old Nov 28, 2019 | 06:14 PM
Dan V's Avatar
Dan V
find the glowplug solenoid and jump it
Old Nov 28, 2019 | 06:50 PM
Walleye Hunter's Avatar
Walleye Hunter
I'm not sure what you are looking for but my F-250 has a fusible link where the feed for it comes off of the starter relay on the passenger's side fender. I don't know where the GPR relay coil gets its power from, I'm not finding a fuse for it.
Walleye Hunter
If his fusible link is blown I don't think that will work.
Old Nov 28, 2019 | 08:59 PM
woodnthings's Avatar
woodnthings
What issue are you having? The GPR doesn't have a fuse The relay is commanded on by the PCM through a ground.
Here is a link to my Glow Plug Page.
If your relay has power and the glow plugs are not working it could be a bad relay or the PCM ground.
Old Nov 29, 2019 | 10:54 AM
BobbyLC's Avatar
BobbyLC
Help
Can someone please tell me where the fuse that controls the Glow plug indicator light on a F 550. 7.3 L power stroke
Old Nov 29, 2019 | 11:09 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
@BobbyLC I have merged two of your threads which were duplicates.
Good luck to you!
Old Nov 29, 2019 | 12:15 PM
woodnthings
The light is controlled by the PCM The only fuse would be for the instruments. What is the problem? If it is not working it is the bulb being bad most likely
Old Nov 29, 2019 | 02:02 PM
Walleye Hunter
And I'm not so sure it's a glow plug indicator light but I am not familiar with the heavier trucks. In ours it's just a 'wait to start' light, which just serves as a reminder for us to hold off on hitting 'start' while the glow plugs warm up. That light goes off after about 15 or 20 seconds but glow plugs remain hot for up to two minutes, depending on engine oil temps and ambient temps.
David Perras
Jul 7, 2015 01:20 PM
fixerupperb286
Bronco II
Feb 16, 2012 05:41 PM
broodog
22
Dec 10, 2011 11:16 PM
f-4x4
Electrical Systems/Wiring
Dec 18, 2004 02:18 PM
powerstroker250
Dec 28, 2002 10:01 AM
