1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Interior Light Disable on F350
Old 10-09-2003, 11:58 PM
Redshift's Avatar
Redshift
Redshift is offline
I saw the instructions to do this on the 150 -- but would
like to know about the F350. (2003)
The manual says that you can turn the interior light dimmer
downward past a detent and the interior lights should go
off. (My 2003 Explorer does this). However, the dealer
has confirmed that this is a misprint.
The fuse layout in the manual doesn't specifically call out
the interior lights -- unless I missed it, and I think there
are two fuses. (I only do this every once in a while when
I am out using the telescope and want to keep the lights
off) -- so I would be willing to pull a fuse or put a switch
in series with the fuse.
Thanks a lot for the help
F350 -2003 4WD
Steve
jasonschwenk
Electrical Systems/Wiring
12-07-2022 08:47 AM
F 250 6 liter
08-24-2010 08:35 PM
toproller
09-14-2008 04:31 PM
sendacheck
03-10-2007 06:20 AM
Quick Reply: Interior Light Disable on F350
