Keypad Code
Old Nov 3, 2019 | 01:06 PM
Dalef250's Avatar
Dalef250
Keypad Code
I just purchased a used 2018 F250 Lariat from a Ford dealer 300 miles away. It has an unlock keypad on the door just as my 3 previous
trucks had. Problem is the keypad card w/ security code was not in the trucks manual as I didn't check before leaving the dealer. I called
this dealer and he was going to contact previous owner. Never heard back so called 3 weeks later and they said the owner was going to
check if he had placed it in his safe. Another call and was told they haven't heard anything but I could go to my local Ford dealer and
have it put on the computer. Well that involves making an appointment, dropping my truck off find me a ride then wait for them
to get to it when they have time. And also paying for this service. Does anyone know how one can get the keycode via any other methods.
Thanks for any input
Old Nov 3, 2019 | 01:19 PM
Willy Sunshine's Avatar
Willy Sunshine
Call the dealer who sold you the truck and ask them to look up the vin number and tell you the master numbers.
Write the numbers inside the cover of the owner’s manual.
I did this a couple years ago with an Explorer. 5 minute phone call. Very simple.
Old Nov 3, 2019 | 01:21 PM
maypo59's Avatar
maypo59
On two expeditions and 1 explorer.. the code was printed on the outside of the ECM case. The Explorer was in the driver's side passenger rear seat inner fender cover thing.. The expeditions were in the passenger footwell front seat, had to remove the kick panel. I assume the trucks are the same, just need to find the ECM
Old Nov 3, 2019 | 02:44 PM
h20camper's Avatar
h20camper
See this post. You need two keys.
https://www.ford-trucks.com/forums/1...l#post18536026
Old Nov 3, 2019 | 03:11 PM
FOURBYBUD's Avatar
FOURBYBUD
Pop off the passenger floor kick panel. The one by their right foot. CODE will be on sticker on the BCM.
Takes 2min.😉
Old Nov 3, 2019 | 05:58 PM
Mattm400's Avatar
Mattm400
Takes 2min.😉
^^^^^^^^THIS^^^^^^^^ I found this on my 13 F150.
Old Nov 3, 2019 | 08:59 PM
speakerfritz's Avatar
speakerfritz
Google this on you tube
if you have two keys, you can get the computer to display the code.
also, I don’t know what version of ford sync software you have....but on my 2018, I can change the code in the software menu to what ever I want .
Old Nov 3, 2019 | 10:32 PM
maxum96's Avatar
maxum96
I bought a used F350 without the code for the keypad. All I had to do was go find the ECU with the code stamped on the back. Literally a 2 minute job.
Old Nov 4, 2019 | 06:44 AM
h20camper's Avatar
h20camper
True on Sync 3 but to do this you have to know the factory code.
Old Nov 4, 2019 | 07:39 PM
Dalef250's Avatar
Dalef250
Thumbs up
Thanks Guys for the replies (posts), decided to try the easiest from h20camper, 8 & 2 and it worked, pretty easy. I now have faith in
these forums
Dale
Old Nov 4, 2019 | 07:42 PM
Dalef250's Avatar
Dalef250
Thank You, it worked
Old Nov 4, 2019 | 10:59 PM
Maiden666's Avatar
Maiden666
Where did you find the ECU?
Old Nov 8, 2019 | 01:38 PM
mbell5263's Avatar
mbell5263
That only works if the dealer records the number in their DMS. Many do not.
Old Nov 8, 2019 | 01:44 PM
Rudeman's Avatar
Rudeman
Now that you have the code, be sure to store it on your phone.
wingheadz
Jul 31, 2011 07:59 PM
DeereTech05
2004 - 2008 F150
13
Jan 30, 2008 02:38 PM
dirtjockey44x
Electrical Systems/Wiring
Mar 16, 2007 11:05 AM
msu_fan
Apr 25, 2004 12:02 PM
qb12xe
16
Feb 20, 2004 03:19 PM
