1999 Expedition trans. problem
Old Oct 22, 2019 | 11:37 PM
EL300B's Avatar
EL300B
Have a 99 Expedition that intermittently will shift up and down between the speeds of 40 to 65 for no reason.Will shift harshly back and forth rapidly,then work fine for several days at a time.Never had a problem under 40 or over 65.Check engine light came on and I had the NAPA dealer check it with his code reader,said to check "ECM"? and or shift solenoid "A"?He also said these vehicles had grounding issues.Been a great rig,any advice??? Thanks
Old Oct 23, 2019 | 08:38 AM
alloro's Avatar
alloro
What was the result when you had the ECM and Shift Solenoid A checked out?
Old Oct 23, 2019 | 11:14 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
What were the actual codes that the Napa dealer found?
Old Nov 9, 2019 | 11:01 PM
EL300B's Avatar
EL300B
I haven't had anything checked yet,other than the code.I like to do my own repairs,partly because I know what was done and who to blame if it's not fixed right.Was hoping someone would tell me what needs changed or fixed as it might be a common problem.Vehicle has been running great lately.I will have to go back and find the exact code and will get back to you. Thanks
Old Nov 10, 2019 | 07:35 PM
pdqford's Avatar
pdqford
Is it actually shifting up and down, or is the TCC engaging/releasing or chattering?
How many miles on vehicle and how many miles on the tranny fluid?
rpstrickland
Mar 16, 2012 11:55 PM
Matt In Detroit
Jan 24, 2010 06:48 PM
sparky00
Feb 13, 2008 04:30 PM
pepster
Sep 20, 2006 01:03 PM
