Frame problem
Old Sep 27, 2019 | 07:19 PM
JPMallory's Avatar
JPMallory
Frame problem
Just got the bed loose from the truck. This is the frame just behind the cab.
Looks like the driver's side was broken completely, and then patched back together unevenly. Passenger side was partially broken, and patched.
Old Sep 27, 2019 | 07:22 PM
56panelford's Avatar
56panelford
looks like your frame was shortened and welded up terribly ..
Old Sep 27, 2019 | 07:28 PM
JPMallory's Avatar
JPMallory
There's a lot wrong with this truck, but I figured as long as the frame was good, I could handle the rest. Yeah...
Old Sep 27, 2019 | 07:35 PM
56panelford
It can be repaired but I'd remove what was used to fish plate for lack of a better word and start over making sure the frame is square before welding the sections together again..Those welds look cold with no penetration
Old Sep 27, 2019 | 07:46 PM
Old F1's Avatar
Old F1
SO, those rotten street rodders (me) cut and join and splice frames regularly, so if you what to: ............. clean it up and hire a welder guy ... OR..... buy a used frame in better shape.
It is all doable, just will take a little longer.
(Dakota front frame into other make car, just don't tell anyone)
Old Sep 27, 2019 | 11:04 PM
Oldb's Avatar
Oldb
Two Words: Certified Welder. Find one with truck frame experience and you will be good as new. But I would not trust it to anyone less.
B
Old Sep 27, 2019 | 11:08 PM
BlueOvalRage's Avatar
BlueOvalRage
I’ve got a buddy in Jamestown that has an F1 frame for sale. That’s right off 74 just northwest of Indy. PM me if you’re interested and I’ll hook you up.
Old Sep 28, 2019 | 07:44 AM
JPMallory's Avatar
JPMallory
Weighing my options right now. I may be getting in touch with you about that frame.
Old Sep 30, 2019 | 12:15 AM
Moe Craig's Avatar
Moe Craig
Wow... that looks nasty. Either replace or repair it right. At least you found it now and can fix it!
Old Sep 30, 2019 | 12:31 AM
Justboy's Avatar
Justboy
Unless you know a welder who would take that on I think it's best to find another frame. A splice done properly would be cut a different way and not straight through. Good luck.
Old Sep 30, 2019 | 03:30 AM
fish pond's Avatar
fish pond
I have a frame (`1950 F1) here as well, its a roller almost ,axles and a motor and trans..
FYI
Greg
spacemarine83
13
Dec 28, 2023 09:43 PM
mybloodisblue
1997 - 2003 F150
99
Sep 26, 2023 11:05 AM
2Hick
Apr 8, 2012 06:04 PM
tazcliff
25
Feb 15, 2011 04:45 PM
scott0531
Sep 14, 2009 02:24 AM
