For you Anderson Hitch haters
Here's your chance to say "I told you so" - as you can see the top ball/post tipped forward and now can't just freely be pulled out.
For pic orientation the truck cab is on the left, the tailgate to the right.
The dealer (and /or Anderson) suspect when originally installed the pyramid wasn't properly seated and the tech just tightened it in place, allowing some play between the pyramid/truck connection. I occasionally checked the bolts for snugness but I never loosened it all and then re-torqued them to specs.
Something I didn't remember until much after is I had earlier that day make a panic stop; several hours later I felt a huge jolt (doing maybe 40 MPG). We stopped, got out - and found nothing so we eventually continued on home. Just as I was getting ready to lift the weight off the truck I noticed this. Are these two events related? I don't know but suspect maybe - but why the delay?
Regardless, I went to my dealer (installer) and they contacted Anderson. Anderson is sending a new hitch.
Good dealer, good Anderson. I still have full confidence in the AUH.
I’d like to see photos of the lower section of the hitch, to see what shift caused this tilt. It would appear, from the limited view, that it was probably caused by an extreme push from the rear, perhaps the panic stop. Had you checked the trailer brakes for proper adjustment lately?
I also had a panic stop recently, but everything basically went into anti-lock and brought things to a stop, safely, but left a lot of rubber on the road. No problem with my Andersen hitch that I am aware of.
Trailer brakes are tested to the point of they work when I activate the manual switch, every time I first pull out; beyond that I haven't a clue.
When the dealer first checked it they were able to circle the pyramid on the ball - so it obviously wasn't resting completely on the bed (close but no cigar). The scary part is it'd been that way for 14 months and 4000 miles.
Tailgate on the left, cab on the right.
I'm not a AUH hater. But that does look complex. I bet it has some virtues that are not immediately apparent.
Check out this system. I don't know what to think. If I could use it to tow my gooseneck behind a tandem dump, it might be nice.
Safety Towing Systems, Inc. ? Now Manufacturing the Automated Safety Hitch System.
My response is the future (boats, planes, even rocketships) are basically now constructed using lightweight composites, this aluminum hitch is an early middle step towards that.
It's actually less complex than a standard hitch that articulates front/rear, side to side and utilizes one or two locking jaws to hold the pin inward - yet being loose enough to allow it to turn with the truck.
While this is my admitted bias I greatly prefer it over my previous "standard fifth" hitches. It offers a greater angle of hitch, unhitch, and I find it quieter. And when comparing it to those airbag equipped hitches (and/or pin boxes) its much less complex. Those items don't do much towards preventing the axles from bouncing - for that they need to slow down. Always good advise.
I've never seen one of those dollys (outside of some commercial rigs) but it would seem to provide an answer in certain applications.
Personally to the OP, I'm glad for you there wasn't a much worse outcome. Glad the company stood by their equipment. Am I a hater, just because that particular hitch doesn't appeal to me? Likewise, I'm not here saying "AH-HA, SEE" either.
I don't push my AUH on others but I will call the haters out when they make claims that aren't accurate.
All mechanical things are subject to wear, breakage, misuse, etc. A single bolt (loose or busted) can be of serious consequence; that includes those 200# iron hitches (with lots of moving parts).
My bringing this failure to light hopefully shows I'm being impartial about it - use the info as you see fit. I feel its advantages outweigh this slight mishap - and I applaud the company for standing behind their product.
What I learned from this is I desire an additional safety - so I have ordered the Andersen Hitch Ultimate Connection Safety Chains with Plate; Part# 3249. $135 on eBay (out of stock on Amazon).
10's of thousands of miles on my steel, rail mounted AUH. I am not a fan of the gooseneck version, but that is just my personal preference.
There are always naysayers when technology or mechanical advancements are made. I know I do it at times, but the AUH will be my hitch of choice for many years. It is too easy to use and move to ignore it.
As I've not been able to find a (single, not set) long 1/4" hex head that'll attached to my 1/2" torque wrench I've just manually checked mine with a standard allen wrench.
As I recall ALL the other bolts are 15/16".
Today I received my Anderson safety chain kit, those parts are stout! I guess (for the job they're expected to perform) they need to be.
Single hex: https://www.protorquetools.com/1-4-w...-bit-socket-1/
Until such time my manual hex key works just fine (once or twice a year).
