Sponsored by: Real Truck
Thoughts on shudder???
Old Sep 18, 2019 | 06:58 AM
SUPERDUTY_08's Avatar
SUPERDUTY_08
My apologies if this has been discussed before. I just got my truck back from having some work done. Thr rear axle yoke was replaced due to a leaking seal, and i had the carrier bearing replaced in an attempt to cure a vibration i occasionally have. However, now when i start to accelerate from a stop, i get a shudder. It goes away quickly. I get this shudder if i start (takeoff) in 1st, 2nd, or 3rd gear from a stop. What are your thoughts?
Old Sep 18, 2019 | 01:43 PM
Tom's Avatar
Tom
If they replaced the yoke, I assume they also replace the U–joint with it?
It almost sounds like the you joint is binding when you're taking off. When you apply power from a stop, the axle is going to deflect and place the U-joints under a greater angle. That might be enough to cause a dry joint to have issues and feel normal when the axle is a more neutral position. Just a wild guess, I would ask your shop about that joint.
Old Sep 18, 2019 | 03:33 PM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
If it's a limited slip put some friction modifier in it and give it a few miles. If the clutches are really dry they with jump and unload even if you are going straight because all it takes the tires to be a little different in size especially if you are loaded because the tires have a harder time slipping to make up the difference.
Denny
Old Sep 18, 2019 | 04:41 PM
SUPERDUTY_08
Truck is stock with 3:73 gears. The shudder happens with no weight in the truck. Ujoints were replaced june 2016 and have about 20k miles on. The mechanic said they didn't need to be replaced. I jacked the truck up today and watched the driveshaft as someone pushed the accelerator. It looked like it was balanced. Spinning didn't look like a uniform rotation. I also had the fluids changed in the front and rear diff, and the transfer case while it was there. All i know is this shudder didn't exist when i dropped it off.
Old Sep 18, 2019 | 04:45 PM
Tom's Avatar
Tom
Denny
This is the most likely culprit if the vibration only happens when turning. My Expedition does this as well.
I f it happens going straight, then it can’t be the LSD because the clutch plates remain stationary with respect to each other.
Old Sep 18, 2019 | 05:37 PM
SUPERDUTY_08
So my axle code is 3L - 3.73 limited slip. So you are suggesting i need to add friction modifier? This shudder happens when driving in a straight line
Old Sep 18, 2019 | 07:05 PM
Tom's Avatar
Tom
Look elsewhere if it happens in a straight line, the clutches are stationary in that situation. Friction modifier wouldn’t affect this.
Old Sep 18, 2019 | 07:18 PM
SUPERDUTY_08
But i probably should add some seeing as i don't see it on my repair bill? Should i siphon some diff fluid out before adding the friction modifier?
Old Sep 18, 2019 | 07:25 PM
rvpuller's Avatar
rvpuller
It's only 4 oz so it's not a problem
Denny
Old Sep 18, 2019 | 08:35 PM
rvpuller's Avatar
rvpuller
I've a lot of ford trucks both work and pleasure and if the clutch pack isn't slipping properly it will jump about anytime it wants to, even straight ahead unless the tires have the same air pressure and wear so the diameter is the same, thats why it had to slip.
Denny
Old Sep 18, 2019 | 08:40 PM
rvpuller's Avatar
rvpuller
Another thing to check when you are under there is your shocks, remove the bottom bolt on both of them to make sure one of them is sticking or locked up. On my present truck I was have a lot of strange noises and banging around back there and one shock was shot and the other one was locking up.
Denny
Old Sep 18, 2019 | 09:41 PM
droldsmorland's Avatar
droldsmorland
Check the things that were removed for the repair...everything tight?
Is the carrier mount tight?
Grab the drive shaft at the rear end and push up/down and see if the yoke or the pinion moves. There should be no detectable up/down deflection.
"Spinning didn't look like a uniform rotation". Define this statement?
Old Sep 19, 2019 | 06:45 AM
SUPERDUTY_08
I didn't know how to properly explain it. Could just be my eyes. Here is a short video
Old Sep 19, 2019 | 06:54 AM
SUPERDUTY_08
Here is another view
Old Sep 19, 2019 | 08:12 AM
rvpuller's Avatar
rvpuller
Its really hard to tell if there is any runout on that slip joint because there is to many things rotating like balancing weights and clips for the boots. But I'm really starting to think you may have a bad U joint. Get your rear wheels off the ground agian and alien the joint so its straight up and down and see if there is any up and down movement, then try it again after rotating the shaft 90' and do it agian, do it agian until all 4 joints have been pointing down. You have to put some force on the joint when checking it not just a little push. If you get any movement your U joint is bad. The one I just replaced on my F150 only had one of the bearings bad and I had to really get after it to get any movement and when I removed the shaft it felt good but i knew there was movement so I beat it out and only one bearing was dry with all the neddle bearings wore flat. Check all the joints.
Denny
