Sponsored by: Real Truck
Fog bulb replacement
Old Sep 12, 2019 | 12:13 PM
Jimv8's Avatar
Jimv8
2002 left is out and don’t know how to get at the back of the fixture and before taking the truck apart thought I should ask here first. Thanks.
Old Sep 12, 2019 | 01:10 PM
SuperDutyScaler's Avatar
SuperDutyScaler
I slid my hand bewteen the license plate mount and fog light (tight squeeze) grab socket and quarter turn it to unclock tabs. Pull back towards radiators then pull bulb and socket back to me, i stall new bulb into socket then reinstall.
It sucks how tight of a fit it is but its better than pulling front bumper. Also recently ive removed the plastic rivets holding liciense plate to bumper, went to parts store and bought four reusable plastic push pins. Now ill just remove liciense plate bracket and have the entire front bumper access open
Old Sep 12, 2019 | 05:48 PM
Jimv8's Avatar
Jimv8
My hand is too big to fit between the plate bracket and the fog lite. I can’t think that Ford engineers would build a non accessible bulb but it’s looking like it and I’m leaning to removing the LP bracket for access.
Old Sep 13, 2019 | 03:53 PM
brian42's Avatar
brian42
Veteran: Navy
My hands are not small and I have sausage fingers. I worked my hands up there to the bulb socket. 1/4 turn and it's out. Same process to install. I did wear some Mechanix gloves to prevent slicing up my fingers on the cooler.
If you want to loosen your bumper to make more room you can do that too. 4 big bolts on the front near the tow hooks (or where they should be) and then 2 in each wheel well IIRC. Remove the bolts in the wheel well and loosen the 4 on the front and the bumper will "sag" a bit and kick out the lower portion with the valance. You should be able to access the fog lights easily then.
jdm5630
Jan 22, 2014 10:06 PM
billydsr25
Escape & Escape Hybrid
Dec 26, 2012 08:23 PM
Texas Outlaw
May 3, 2007 09:30 PM
dusty1
2004 - 2008 F150
Mar 11, 2004 10:10 PM
exzist51
Jun 19, 2003 02:49 PM
