Front end vibration - FIXED!
Old Aug 25, 2019 | 08:14 AM
Teutonics's Avatar
Teutonics
Finally.... after ~30k miles, new tires, new shocks, new ball joints, alignment, wheels re-balanced five(!) times by four different shops (including road force balance), numerous google search sessions finding lots of similar complaints with no resolutions... all of which did not solve the problem, I think I've fixed the front end vibration. The wheel bearings! After re-tightening both sides per repair manual procedure, an initial test drive shows the problem gone! 70-75mph with no issues!
It's a fairly simple and easy process (and free!), so definitely something to try first before all of the other items listed above... :-\
The vibration usually manifested itself 69-75mph, but only after driving a while to where everything would get up to temperature. I'm still cautiously optimistic, but have a 18 hour trip coming up that will fully put it to the test. I'll follow up with confirmation (or tears of sorrow) if it's not fixed...
Hopefully this helps someone else with the "unsolvable" vibration felt through the steering wheel.
Old Aug 25, 2019 | 01:17 PM
Spaznaut's Avatar
Spaznaut
Can you list the repair manual procedure for tightening those?
Old Aug 25, 2019 | 02:16 PM
jimbomitch's Avatar
jimbomitch
Sad that all those shops could figure out loose wheel bearings being the root cause.
Old Aug 25, 2019 | 09:09 PM
Teutonics's Avatar
Teutonics
After removing grease cap, cotter pin, and lock cap, spin wheel counter-clockwise while torquing spindle nut to 17-25 ft-lb.
Stop wheel (do not spin), loosen spindle nut 1/2 turn.
Retorque spindle nut to 22-25 in-lb (note that this is INCH-POUNDS, not foot-pounds as is listed above.
Reassemble lock cap, cotter pin, and grease cap.
VERY SAD!!! (and expensive!) The state of many auto shops today... :-(
Old Aug 26, 2019 | 05:08 AM
JWA's Avatar
JWA
We all lament the state of auto repair shops these days--its becoming nearly impossible to find enough people motivated to do the work, forget learning enough to keep current on changing technologies auto repair involves these days.
As for the grease cap--make sure they fit tight into the hub. I had my front rotors and bearings replaced, one side grease cap didn't fit snugly as would be normal. After a few miles it fell off inside the dog dish wheel cover making a small grease mess inside. Reinstalled it a few times only to have it keep falling out so finally ordered new ones from Ford---about $9 a pair direct from the dealer. If those don't fit snugly its a good idea to consider replacing them. Then again those so rarely need replaced its understandably overlooked.
Old Aug 27, 2019 | 09:50 AM
BAD RONALD's Avatar
BAD RONALD
Just replaced wheel bearings on my '04 E350 at 92K mi (parts I used are linked below- I gave up on finding non Chinese made). Never had high speed vibrations but a noticeable rotation grind/groan occurred at a low speed hard left turn.
The spindle nut torque is not much, I will be double checking it in the next week or two for any change in seating.
https://www.rockauto.com/en/moreinfo...sn=588&jsn=588
https://www.rockauto.com/en/moreinfo...427622&jsn=720
https://www.rockauto.com/en/moreinfo...sn=805&jsn=805
https://www.rockauto.com/en/moreinfo...427622&jsn=806
Old Aug 28, 2019 | 09:57 AM
JWA's Avatar
JWA
I bought my previous set from the dealer---about the same cost, undoubtedly much much better quality.
Sadly RockAuto is becoming a site I avoid buying from unless its Motorcraft brand. Too many other products that are "off shore" produced, it does take more time and perhaps a bit more money to find anything but Chinese crap. Lucky for me I have enough of both most days.
montana_highboy
21
Sep 22, 2017 03:47 PM
sleep_deprived129
Jul 25, 2013 07:51 PM
bintopo
Escape & Escape Hybrid
Jun 12, 2011 09:25 AM
2003 6.0
Aug 30, 2007 12:04 AM
fordfla
Aug 23, 2004 11:30 PM
