Manual Trans issue
Old Aug 14, 2019 | 04:17 PM
SynDave's Avatar
SynDave
Manual Trans issue
Hello, my 84 f150 4.9l wont go into gear. Any ideas what could cause this? It will start up with the clutch and that's it. I can feel it vibrating when I shift into gears 3 and 4 in park but that's it
Old Aug 14, 2019 | 04:32 PM
85e150's Avatar
85e150
Can you get it into gear without the engine running?
Old Aug 14, 2019 | 04:49 PM
SynDave's Avatar
SynDave
Yeah it will go into gear with engine off. It will some times go into gear while running but not move when I get off clutch
Old Aug 14, 2019 | 05:07 PM
85e150's Avatar
85e150
4 speed with a very low first gear?
Or 4 speed with 4th as OD?
Old Aug 14, 2019 | 05:13 PM
85e150's Avatar
85e150
Regardless, the first step here would be to inspect the clutch linkage, starting at the pad on the pedal and ending where the fork goes into the bell. Pay attention to where your master attaches to the firewall. These are known to crack. Rust makes it worse.
IF that is all square and the clutch fork is moving properly, lift the carpet and remove the transmission tunnel cover. If you have the low first gear transmission, you can remove the top cover and inspect the shift rails, shifter engagement etc.
Old Aug 14, 2019 | 05:15 PM
SynDave's Avatar
SynDave
Okay thank you!!
Old Aug 17, 2019 | 03:50 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1984 F150 w/300 I-6: It's probably the RTS TS-OD Top Shift 4 Speed Overdrive.
The multi-piece shift lever caused all sorts of shifting problems, even when new. The plastic bushings snapped, were only available w/the shift lever.
Here's a pic of the puppy:
jasoncw
Nov 13, 2013 02:05 PM
tiltbilt
Nov 16, 2010 10:15 AM
michbol
Oct 21, 2010 07:03 PM
mechelement
18
Dec 17, 2009 09:25 AM
robin22m
Mar 24, 2009 04:31 AM
