1994 f350 engine issues
Old Aug 8, 2019 | 10:46 PM
bootless1075's Avatar
bootless1075
so i just bought a 1994 f350 crew cab long bed with the 351 previous owner said it started to knock he shut it off had it towed home let it set tried to start it and nothing but a loud hard thud it has some water in the oil and it looks like its trying to spin over im thinking it has water in the cylinder but im not going to be able to pull the plugs till this weekend what are the chances its not a head gasket and bad rod bearing please give me good news
Old Aug 10, 2019 | 02:04 AM
bootless1075
well im going to pull the plugs in the morning
Old Aug 11, 2019 | 10:07 PM
bootless1075
well i believe this motor is shot when i put water in the radiator it pours out the oil drain plug faster than i can pour it in
Old Aug 12, 2019 | 01:39 PM
Da_Lariat_Chariot's Avatar
Da_Lariat_Chariot
Sounds like a cracked block then. Sorry bud.
Old Aug 16, 2019 | 08:46 PM
bootless1075
i found another motor from a 95 f15 im getting do these trucks use the same cam?
Old Aug 17, 2019 | 12:19 PM
Phase3's Avatar
Phase3
1994 and up should be roller cam. Your truck, being a changeover year, would need verified. Either has a billet distributor gear or cast gear. You can visually see the difference. Cast is aggressively and sharply machined. Billet is smoother. Cast gear is non roller.
Old Aug 17, 2019 | 05:58 PM
torq'ta 5 8's Avatar
torq'ta 5 8
you could pull lifter out, sometimes its hard to tell on gear look, guy just posted about his with pics
flat tappet lifter
roller cam lifter
Old Aug 17, 2019 | 07:38 PM
timbersteel's Avatar
timbersteel
Can also pull valve cover, loosen rocker arm, and check pushrod length. That would be the easiest method without disturbing the lower intake and having to reseal it.
Flat tappet are longer, roller lifters use a shorter pushrod.
Someone chime in if I got the lengths backwards.
Old Aug 17, 2019 | 07:46 PM
torq'ta 5 8
flat tappet-8.1"
roller-7.5"
Old Aug 17, 2019 | 07:47 PM
timbersteel
Originally Posted by torq'ta 5 8
flat tappet-8.1"
roller-7.5"
Thanks torq'ta!
Old Aug 18, 2019 | 06:34 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Why would that matter? I wouldn’t be using anything from the dead engine except the wiring harness. Seems to me it would be a lot easier to swap out long blocks.
