Will Ford Increase 2020 GVWR to Meet or Beat GM?
#31
Huh! You are kidding! Then why has Ram built their SRW truck to 12,300# or GM SRW now at 12,250? ....because customers want the extra GVWR in an SRW truck. I was easily towing 14,000# with a Ram while my F350 was borderline.
#32
Bring on the higher GVWR.
#33
Im liking the self driving features too. These features should be standard for the bucks we are paying. We have been paying Tesla prices for years.
#34
#35
#36
#37
#38
#39
Nope , a gooseneck rests its weight in the bed of the truck. If you got a light weight truck it’s easy to run out of GVWR. Getting a non commercial DL isn’t hard....just buck up. There is no logbooks with a non commercial license. Federal regs have changed that’s why they created a special test for drivers who tow heavy.
#40
#41
Well 5th wheel is usually private and generally heavier on the pin, and has passengers/cargo in the truck. I can see how it wouldn’t matter 11,500 or 12,300 if your trailer is rated over 16,000 anyway. Getting a class A is pretty ‘vanilla’ compared to a CDL.
When i hook up to a GN its just me. My cargo is a cup of coffee and a case of water usually. I go off the axle weights and combined GCWR, if they change that and enforce it hard enough I’ll just register it for 11,940, the axle weight ratings.
I can be about 16k on the trailer and I’m under CDL weights and right at Fords advertised GCWR for this truck.
Anyway.... Different scenarios but if I had a 12,300 GCWR truck I would definitely get a ticket as they routinely tag duallies pulling goosenecks.
#42
#43
#44
The DMV looks at the GVWR on the truck, then trailer, if two are greater than 26,001 you’ll need a non Commercial DL. There’s nothing to do with axle ratings. Most of us get heavy because we have aux fuel tanks. At 8 mpg the 48 gallon tank is gone quickly. If you take the non commercial test, there is no break testing or physical exam. Done.
Anyway, I printed the regulations from the MD MVA that say it's weight and not weight rating and keep them in my truck with one of my 25.5k weight slips and roll with my class C.
#45
Lariat,
Actually its commercial use so CDL. My company uses this F250 to pick up material on holidays, weekends, or in pinches.
Whats funny is these hotshot guys in DRW trying to stay under CDL probably haul less than I can. Of course legally and per Ford also. I follow the yellow sticker on the door, white sticker, and GCWR Ford advertises.
For Commercial a 10,000 F250 is usually pretty adequate if unless you want a CDL.
