I know this isn't the Chevy/GM forums...
Still lots of people here, like myself, that like to keep current about what's happening in the truck market. So figured I'd ask because I can't find the answer ... how is Chevy/GM creating a new GVWR of 11,500lbs for a "3/4 ton" truck and somehow (dodging? solving/avoiding?) the 10,000lb GVWR class 2 DOT restriction? Or are they? Or am I completely off base thinking this is even an issue... I guess I'm confused because I have been a believer that the 3/4T (regardless of manufacturer) has always been a paper/sticker rating - not a physical rating. Looking for example at current F-250 6.7L, the FAWR is 5000lbs and RAWR is 6200lbs (at least it is on my '19), giving 11,200lbs (even OEM 18" tires are 3400lbs capacity/ea). So what's the angle/trick/change of the 2020 Chevy/GM 2500 that Ram/Ford haven't done?
Maybe I missed it, but I haven't seen any official GM documentation that says they're increasing the GVWR, just documents that they're increasing the GCWR:
https://plants.gm.com/media/us/en/ch...2020.tab1.html
https://www.gmc.com/gmc-life/trucks/...rra-heavy-duty
These never mention the GVWR rating being changed.
It's a question better asked over at a Chevy/GM forum. Not being flippant. Just being realistic. Those guys know their trucks and manufacturer as well as we do ours.
But, also realize that you can get a Ford F-350 SRW, normally 11,500 lbs, with a 10,000/9,900 GVWR rating. So, there you go.
Funny that I literally just posted a thread on this same topic.
I don't think there is any official restriction that says "3/4 ton" (a fake designation) trucks must be Class 2 vehicles. I believe Ford assigns the 10,000 pound GVWR to the F-250 for marketing reasons. Why else would Ford offer trucks that are nearly identical mechanically but their GVWR differs by 1500 pounds? The only difference between my F-250 with the High Capacity Trailer Tow Package and a F-350 is a slightly different leaf spring configuration. I seriously doubt that the slight difference in deflection rates justifies the 1500 pound bump in GVWR/payload.
GM said screw it, and for 2020 will build certain 2500 trucks that are Class 3 vehicles with a GVWR and payload ratings that exceed a F-350. They will also build other 2500s that maintain their status as Class 2 trucks. Why? What is their strategy? I don't know the answer to that question?
So why would you be glad you have a less capable truck? Just curious. Should you buy a New GM you can always declare a 10,000# GVWR for your extra capable Silverado. Looks like companies are giving the consumer the choice of GVWR best for them.
JD'sBigredv10
2017+ Super Duty
71
08-02-2019 04:52 PM
eastburn
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
12-07-2003 11:57 PM
