Need More Power In My 95 f150 5.8 liter
Old 07-11-2019, 03:22 PM
Bradley Freeman
Bradley Freeman is offline
Bradley Freeman is starting off with a positive reputation.
Want so more power in my truck. What should I put on it?
Old 07-11-2019, 04:06 PM
Conanski's Avatar
Conanski
Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
Gears might be your best move, what does it have now and what size tires are on it.?
Old 07-12-2019, 09:46 PM
Blurry94's Avatar
Blurry94
Blurry94 is offline
Blurry94 has a great reputation on FTE.Blurry94 has a great reputation on FTE.Blurry94 has a great reputation on FTE.Blurry94 has a great reputation on FTE.
Pull the spout connector out and bump the base timing up a couple of degrees. That lil mod is noticeable and free.
Old 07-13-2019, 12:33 AM
baddad457
baddad457 is offline
baddad457 has a great reputation on FTE.baddad457 has a great reputation on FTE.baddad457 has a great reputation on FTE.baddad457 has a great reputation on FTE.baddad457 has a great reputation on FTE.baddad457 has a great reputation on FTE.
Careful with gears. I changed mine from 3.55 to 4.10's and it didn't like the change at low speeds when you nailed the go pedal. Changing the stock stamped rockers to 1.7 full rollers will net you some power and free up the friction by replacing the sled fulcrums to roller trunions.. Shorty headers will help some too. And these are pretty easy to upgrade to a 3" single exhaust. Going to a K&N air filter and removing the silencer from the air box will help too
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
