Rusty MI F250 frame, worth coating? (Pics attached)
Hello, I’m new here and just wanted to get some members opinions on frame coating. I just picked up this 2000 F250 with the 6.8l V10, 170k miles. So far it’s been a good truck. I’m wanting to keep it for awhile, but the frame has me a little concerned. It’s from MI and has pitting and flaking on the frame from the salt. I’ve called a few places about doing a rust converter/inhibitor frame/undercoating. I am just wanting your opinions on whether or not it’d be beneficial to spend the money. I want to put on a leveling kit, wheels, and bigger tires, amongst other things. I also plan on doing some welding/reinforcement to the rusty bed. Before I dive in to all of that, will this frame last me long term, or should I look for another F250 and save the undercoating and other expenses for a new toy hauler.
My intentions are to pull a tri-axle trailer and a 1989 F250 I have that has a dump bed and plow. I’ll use the truck/trailer for loads of stone/dirt and picking up/hauling other vehicles. It’s always good to keep a truck around, and I’ve never looked back since owning my first F250, several diesel and gas variants later. Thanks for anyone who cares to help and give their opinion!!!
I don't think that frame is shot. I would give it a good cleaning and use something like nh oil undercoat to preserve it. They sell a back in black product that really makes a surface rusted frame look good. I don't work for them, don't get paid for an endorsement, but have had great luck with the product.
and thanks to both the replies reference the New Hampshire oil. I will definitely be looking in to that!
If the frame is toast, maybe I shouldn’t waste more time. Mixed reviews so far... thanks for all who have gave input!
Granted the pictures don't tell the whole story; but you guys that call that frame toast, I don't know what you're used to seeing where you may live but I would say that's typical of an older truck up north. I've seen much worse on newer trucks so that's actually not bad for 19 years old. I'd start by wire brushing that and then follow up with a product like Eastwood's POR-15 or something similar. Then Fluid-Film it every year to keep it clean. May cost you some $$$ but it's cheaper than a new truck! Those are just my thoughts anyway.
The bed could use new rail supports. I’ve found a few places that sell them. Then I was thinking about welding new piece of decent gauge sheet metal down.
Good idea!
These look like good options:
https://www.harborfreight.com/compac...ler-96997.html
https://www.homedepot.com/p/Powermat...xoCQjkQAvD_BwE
https://www.amazon.com/Rockwood-Pistol-Needle-Pneumatic-Deburring/dp/B07PWH5VSG/ref=asc_df_B07PWH5VSG/?tag=hyprod-20&linkCode=df0&hvadid=343230804212&hvpos=1o3&hvnetw=g&hvrand=12764822116972445317&hvpone=&hvptwo=&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=9016344&hvtargid=pla-728588963993&psc=1&tag=&ref=&adgrpid=70737352762&hvpone=&hvptwo=&hvadid=343230804212&hvpos=1o3&hvnetw=g&hvrand=12764822116972445317&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=9016344&hvtargid=pla-728588963993
These threads should be helpful in seeing a before and after:
I have had good luck with Chassis Saver other swear by POR15. If you don't to that, clean the frame and coat the underneath with used motor oil, bar and chain oil (my preference), or Fluid Film.
Your frame looks fine to me regardless of the body rust. Just remember, rust is automotive cancer. The only try way to fix it is completely remove it. Otherwise, you can slow it down but never truly stop it.
- https://www.ford-trucks.com/forums/1...r-salvage.html
- https://www.ford-trucks.com/forums/1...ld-i-do-2.html
