What are the symptoms of a bad tank selector?
The truck is an 86 F150 XL w/ 351W HO and dual tanks. The carb wasn't getting fuel last August and I replaced the mechanical pump which seemed to be the issue. Lately I've been running into fuel starve issues again and found that the carb wasn't getting fuel again. So I pulled the pump again and the arm flops up and down by just shaking it so the diaphram/spring inside is toast. I did have a used pump that came with a used carb I bought just hanging out so I put it on and it still seems to not be pulling fuel. But I also don't know for sure if that pump is fully functional.
So, this truck does not have pumps in the tanks, just senders and I've only been running it on the front tank because the gauge doesn't read on the rear and I wasn't sure if I was even getting fuel from the rear. So are the 3 port selector valves in these trucks the ones I hear people having a lot of issues with? And what are the usual symptoms of the 3 port valve going out?
My '84 has a 3 port valve and it is spring-loaded to draw from the aft tank. It requires power to draw from the front tank. Remove power and the valve automatically draws from the rear tank. I learned about this years ago when the fuse worked loose due to vibrations from retracting the parking brake lever. I had the selector switch set to the front tank, which never decreased because fuel was being drawn from the rear tank.
Not positive, but I think this was reversed onlater models. I'd have to research to be sure. The spring-loaded default was to feed from the front tank.
Edit: Per the EVTM, from at least '84-86, the default was to feed from the rear tank. The '81 EVTM shows the front tank was default. I'm not sure exactly when the changeover occured, but it was somewhere from '81-84.
In theory, yes. This is only true if the valve passages are fully open. If there's an internal blockage such as a loose seal (You picked a fine time to leave me...), then all bets are off.
Make sure you see the edit to my previous post about the changes in the default position.
Those plastic clips are sometimes available in auto parts stores that have a Dorman HELP! section. They're pretty flimsy and break pretty easily.
https://www.amazon.com/Dorman-HELP-5...ype=automotive
They did come off with a little pry of a flathead. I didn't experience the large amounts of fuel loss that has been reported by others. The valve does not seem to be switching tanks so I will test for power at the plug next and (fingers crossed) have this ironed out this evening. I appreciate the help everybody!
