What are the symptoms of a bad tank selector?
I bench tested it with a 12VDC wall wart w/ 1.0 amp output I heard it try but I didn't know if it was enough amperage. I put it back on the harness and tested it for change of flow by blowing through the pump port, and it didn't switch still. This truck is just for hauling scrap to the scrap yard so I'm not putting a whole lot of effort into retro fitting any of the only 5 options out there for a new valve on limited funds and I have only been using the front tank anyway because it has the sender that works so I flipped the valve around and swapped the ports for the rear and front tank, left the harness unplugged and am leaving the selector switch on the front so I have a fuel gauge.
OldWoodsDiesel
05-15-2013 04:27 PM
palletcutter
35
03-02-2012 05:51 AM
88F-150pimp
11-02-2007 07:27 PM
